83 Cutlass Supreme Brougham 307 5.0L
Old Dec 2, 2006 | 03:31 PM
83SupremeBrougham's Avatar
I need some help with some starting problems. My car Blow's really dark black smoke out of the tailpipe evertime I start the car and makes a belt like squeeling sound,I have already changed all the belts can't find the squeel,but after the car squeels it powers up and the smoke takes a min or 2 to clear out and the car runs perfectly fine after it's running.I have already put on new,plugs,wire's,distributor cap,all the belts,new altenator,new battery,brand new radiator.And now it won't start at all. It starts and then it fire's here and there and there's plenty of gas getting to the carb. Can anyone tell me if they think my problem lie's somewhere in my emissions\oxygen sensor\cadalitic converter\air pump type area?? I love this old car and I'm not ready to give up on her yet,but I just cant figure this one out.
Old Dec 2, 2006 | 08:53 PM
mjscutlass's Avatar
look at these problems.
The black smoke tells me that ur running rich. U may be fowling out the plugs. When u try and start it and it won't start pull a couple of plugs and C if they are wet and smell like gas.If that is the prob. then u need to have the carburator rebuilt.
Old Dec 5, 2006 | 03:42 PM
Hey thanks 4 the reply mjcutlass. I think you might be right because when I replaced the plugs about 4 weeks ago a couple of them were burnt out and it was heavy with gas in there.And when I'm tring to get it started now the new plugs are wet. Is there anything I can do to get around that carb just to get it to fire-up? Because after about 3 mins it heats up and the problem goes away. Just untill I can find a reasonable priced carb.
Old Dec 6, 2006 | 02:33 AM
Redog's Avatar
You can lean the carb out a bit
Old Dec 7, 2006 | 07:12 AM
mjscutlass's Avatar
UR carb
The carburater on ur car is computer controled.(NO ADJUSTMENT) If the carburater is the stock one. Depends on how far u are from me but i have a good carb. I just pulled it off a 83 cutlass(put a big block in it)
Wildcard
Nov 29, 2012 08:52 PM
carbonf00tprint
Nov 4, 2012 07:53 AM
69Rman
Mar 16, 2009 05:40 PM
<RonC>
Jun 22, 2004 12:36 PM
