72 Decode help
Old Mar 8, 2024 | 04:27 AM
Kirkw810's Avatar
72 Decode help
Good morning all, could use a little help please.
I believe it reads 72 34257 LAN457347 977 36 36 4D A53 any help on decoding is appreciated Thank you
Old Mar 8, 2024 | 05:54 AM
ST 72 = 1972 model year
34257 = Oldsmobile (3) Cutlass Supreme (42) Hardtop Coupe (57)
LAN = Lansing assembly plant
457347 BDY = Fisher Body sequence number
TR 977 = White vinyl bench seat interior with arm rest
36 36 PNT = Radiant Green (36) lower and upper body color (a Supreme HT without a vinyl top!)
4D = built fourth week (D) of April (4) 1972
A53 = this is most likely actually A65, which is the RPO code for the custom sport bench seat with the arm rest.
Old Mar 8, 2024 | 06:23 AM
Kirkw810's Avatar
Cool, thank you. It's actually got power bucket seats ww/center console. It's highly optioned with rear defroster, 8 track, power windows, power locks, seat belt buzzer when unplugged. Again, Thank you very much
Old Mar 8, 2024 | 06:41 AM
leftlaneonly's Avatar
pic's
Old Mar 8, 2024 | 07:40 AM
Kirkw810's Avatar
Pics.
Old Mar 8, 2024 | 11:42 AM
70W-32's Avatar
A52 is Bench Seat, and your 977 trim code is white bench seat, so the buckets and console were probably swapped by a previous owner.
Old Mar 8, 2024 | 12:17 PM
Kirkw810's Avatar
My guess also, thanks to all..
Old Mar 8, 2024 | 01:57 PM
And likely a lot of that other optional equipment.
Old Mar 8, 2024 | 03:14 PM
Kirkw810's Avatar
Appreciate all the help..
Old Mar 8, 2024 | 03:22 PM
Hang on, I posted too soon. In 1972, Olds used the same trim codes for bench and bucket seat interiors. This is unlike prior years. The actual seat style was stamped on the cowl tag.
That's probably an A51, which designates the bucket seats that were standard equipment on the Supreme Hardtop Coupe. Note that Supremes were not available with the RPO A52 Bench Seat, only with the RPO A65 Custom Sport Bench Seat with the arm rest. The Trim Code would have been 977 either way. Sorry for the misinformation.
Old Mar 8, 2024 | 03:31 PM
Kirkw810's Avatar
Well that's a +
Old Mar 8, 2024 | 08:30 PM
rocketraider's Avatar
Oldsdruid
Wouldn't a factory console car have had D55 on the data plate, since Fisher had to install the mounting brackets?
Old Mar 9, 2024 | 05:51 AM
Not necessarily. I've seen a lot of cars that did not have it
Old Mar 11, 2024 | 05:59 AM
Kirkw810's Avatar
Hmmm..
Found this connected to passenger bucket seat, so it is a bucket seat car.
Old Mar 11, 2024 | 06:03 AM
Nice. Fixed it for you.
Old Mar 11, 2024 | 06:31 AM
Kirkw810's Avatar
Cool, thnx
Randomone
Jul 1, 2023 03:27 PM
David Hafley
Jun 26, 2022 08:35 AM
1970VistaCruiser
May 27, 2020 02:12 PM
woodie582
Jan 13, 2013 06:48 PM
72cuttycoupe
Jun 21, 2012 07:42 AM
