71 cutlass radiator
Old Jun 22, 2020 | 09:28 AM
coppertopgmc's Avatar
71 cutlass radiator
Need to replace my radiator but want to stay with the correct brass/copper. the car now has a 4 row brass/copper but does not fit correct in lower saddles and i don't want to replace them. also the upper mounting plate is all bent from being modified to fit the current radiator. did they only make two different top plates? I have one from a 2 core radiator.
Old Jun 22, 2020 | 10:20 AM
RetroRanger's Avatar
72 Olds CS
Yes the 4 core top plate had wider saddles, they sell replacement wide lower saddles, some peoplejust hammer modify thelower saddles. Partsplace sells a repro 4 core top plate. One member ( maybe funkwagon) trimmed his 3 core top plate and added the 4 core saddles making a nice looking 4 core top plate
Old Jun 22, 2020 | 10:26 AM
If you want to run a copper four row, you must change the lower saddles and top plate, or else you need to beat the heck out of them. There is no option - the four row uses wider end tanks than the two and three row radiators. You can get an aluminum radiator that provides the cooling capacity of the four row copper but has end tanks that fit in the smaller saddles. Or, you can replace the saddles and top plates.
Old Jun 22, 2020 | 05:13 PM
72 Olds CS
heres a pic of a three core top plate that has been modified to fit a 4 core rad.
not my pic i got it from here
johncj5
Jan 22, 2017 05:47 PM
truckman5000
Jun 9, 2016 01:44 PM
ctreutel
Oct 27, 2013 01:54 PM
kitfoxdave
May 27, 2013 01:28 AM
Texas442
Dec 8, 2010 08:16 AM
