64 Cutlass with a 70 350.
Old May 30, 2015 | 09:00 AM
Mike Sundy's Avatar
Hey all,
I am new to the forum. I bought a project Cutlass and saying it has some issues would be an understatement. The one that I would appreciate help on today is the electrical. So the engine runs and the battery holds a charge when running but dies over night, even with a new battery. None of the lights or the horn work. Could anyone suggest the best way to start? Also, if anyone has that wiring diagram, I would greatly appreciate it.
Old May 30, 2015 | 09:36 AM
Welcome. I moved your post to it's own thread because you'll typically get better answers that way than resurrecting a thread from 2011 that's only mildly related. You need to start by getting a factory Chassis Service Manual, which has the wiring info plus everything else you'll need to fix this car. Get an original paper copy, not an electronic version or reprint, because all the electronic versions and reprints are simply scans of an original paper copy and detail gets lost in the translation. Originals are on ebay all the time. Note that this is a five volume set.
The real question is, what was done to the wiring when the engine was swapped? It's hard to help on a car that isn't stock without knowing what mods were done. Basic troubleshooting for a power drain is to isolate circuits, either by pulling fuses or connectors, until you find the one that caused the drain, then find the short.
Has this car been converted to an internally-regulated alternator? If that wasn't done properly, that can also be a source of the problem. Good luck.
Old May 30, 2015 | 10:16 AM
Mike Sundy's Avatar
Hey Joe,
Thanks for the quick reply! I'm not entirely sure how it was wired. The guy I bought it from got it from another guy with the engine already in it. I'm going to attach a picture of the alternator. He was only sure that it was a 350. From looking at the headers, the markings seem to indicate a 1970 350. They have a 7 on them near the alternator. I can't be sure that there is a short draining the battery as the old battery was bad. With the new battery the discharge isn't that noticeable but the lights and horn still don't work.
Old May 30, 2015 | 10:30 AM
Mike Sundy's Avatar
Whoops, wrong picture!
Old May 30, 2015 | 12:00 PM
Mike Sundy's Avatar
Here are a couple wiring pics.
QS442
Nov 30, 2011 05:45 PM
halfmoontrail
Drivetrain/Differentials
Jul 1, 2011 09:08 AM
dharlett
Sep 23, 2009 03:30 PM
jd75
Jun 1, 2009 01:56 PM
65cutty
Sep 28, 2008 06:13 PM
