455 Into 68 Cutlass S Convertible
Tried searching but couldn't find anything specific to this. What sort of issues will I run into putting a 455 into a 68 Cutlass being that the 68 would only have had a 350 or 400. Any and all info greatly appreciated. Thanks in advance!!
You won't run into any issues putting a 455 in it. It bolts right up. This question has been asked many times on here so there is lot of treads with info on this. One question is always about engine mounts what ever ones you have will work. If it had a sbo than you can use those mounts. You can use your same brackets. You have to use the right water pump for the brackets.
As for swapping the 455 into a 68, be aware that from the factory, the big block and small blocks used the same motor and frame mounts in 1968. MOST VENDORS INCORRECTLY LIST THE 69-72 MOUNTS AS FITTING 1968 ALSO. The correct 1968 mount will be the same as the 350 mount. Anchor #2261 is the correct motor mount if your originals need replacing.
You'll need the correct BBO exhaust manifolds or headers. The 69-72 W/Z manifolds will fit the 68 chassis but will not be "factory correct" for a 68 BBO, if you care.
What could account for the engine sitting low or just not lining up with the fan shroud? I ask because I just noticed the bottom of the fan shroud is cut away to make room for the fan. At the top there is about 1.5" clearance between the fan and shroud. My parts manual indicates that the fan shroud was the same for all V8 engines on the cutlass in 68 so it has me a bit baffled. Could it be an issue with the motor/fame mounts as Joe P. stated above or maybe the water pump issue as stated by Andy?
As always....thanks in advance.
Hi John
There were different diameter fan blades and my guess is you've got the larger diameter blades on your 1971 engine. There are some past threads discussing this too as your not the first person who's struggled with this. That's why my 1970 has the bottom cut out of the fan shroud.
John
![Embarrassment](https://classicoldsmobile.com/forums/images/smilies/redface.gif)
Either the entire engine/trans combo is tipped down at the front or there's a problem with an incorrect shroud and/or fan. Note that 1968 shrouds are different from the 69-72 shrouds.
I HAVE had a situation where someone had lifted the car with the jack points midway down the frame rails, and had distorted the lower flange of the frame. This caused the crossmember to sit too high, raising the trans and pitching the engine down in front. Alternately, a bent or incorrect trans crossmember could do the same thing.
I'm running a 4 row radiator with it and have no problem in the summer. In my part of the country there may be one or two weeks over 100 degrees, then several weeks in the 90's. I don't know exactly what years used the different sized fans blades, but I have measured 19" and 19 1/2" fans on 1968-72 engines. These were all 6 blade clutch fans. Several years ago I tried 3 or 4 different shrouds on my 1970 before giving up and cutting the bottom center out of one. Since then I read a thread on this site explaining the different diameter blades and realized my mistake. John
As new owners emerge we run into the same problems....guess I should have put more effort into searching....sorry.
Uh....now I just feel stupid. I should have realized this myself. Kinda ashamed considering I'm in a mechanical field of work.
Any idea on the difference? I did find the part number on the one that's in there and it is the 69-72 shroud. I appears though that all the aftermarket shrouds are listed as 68-72.
Ouch....I'll look into this one but hope it doesn't apply. Sounds tough to correct.
All good information....Thanks guys!!!
That wasn't meant to be a personal criticism, just an observation that many people seem to have a problem with fan shroud clearance lately. The Olds motor mounts can be confusing. Welcome and good luck.
Was the cutlass originally fitted with an inline 6? Don't know if the fan is in a different position but thought I'd offer it as a possibility.
My cutlass S vert came with a 6 cyl.
I installed an electric fan on mine so I don't know what would have happened with the original shroud.
