1972 cutlass supreme
Old Aug 25, 2009 | 05:54 PM
andrew.minarick1's Avatar
Im looking at a 1972 cutlass supreme to buy but the shifter is on the steering colom. Is there any way that i could somehow tranfer the shifter so it is on the floor like some?
Old Aug 25, 2009 | 06:18 PM
2blu442's Avatar
Yes, you can purchase the parts to make the conversion and if your handy with tools it's not a difficult swap. John
Old Aug 25, 2009 | 06:33 PM
thanks, also would it be possible to make it into a manual transmition?
Old Aug 25, 2009 | 06:59 PM
2blu442's Avatar
Hello Andrew
Yes, it can be converted to a manual transmission too. It's just a matter of making a list of parts needed, then purchasing them as you can and finally installing them. Once again, not difficult to do if you feel comfortable turning wrenches. John
Old Aug 26, 2009 | 04:29 AM
I would say Changing to a floor shift A/T is a whole lot easier than changing to a manual.
I beleive I have an extra floor shift steering column around here somewhere. [black] PM me if ya need one. You should also change out the speedo and get rid of the PRND etc
Old Aug 26, 2009 | 06:18 AM
lshlsh2's Avatar
71 cutlass convertible
If your going to do all this work you might consider changing the trans over to an overdrive unit like a 200r4. It is almost a bolt in for a 350. Just remember if you have built up the engine make sure that you have the trans built to take it.
This project is on my wish list along with many others.
Larry
travisbeamon
Apr 6, 2013 09:37 AM
Oldssupreme
Jan 14, 2013 10:08 AM
olds70supreme
Aug 1, 2011 05:22 PM
Cutlass72Supreme
Dec 13, 2006 03:14 PM
mumpspro
Sep 24, 2006 11:03 AM
