1972 Cutlass S ?
Old May 29, 2014 | 08:28 PM
  #121
bainer1290's Avatar
Well guys made a fatal error with the rad haha this is such a dumb *** move I am almost embarrassed to share this but I went to test fit it and the damn thing is too big! I failed to do that before doing all the work cleaning, testing and painting it. Previous owner must have made this error too as the rad was in the trunk of the parts care... The core on this rad is about 30.5 inches if I remember correctly it had a tag on it that I traced to a 1980's Cadillac, so I ended up ordering a Vista-Pro Ready Rad 433322, saw that others have had great success with it. It is not an original brass/copper rad but my car is far from original and really I just want something that will cool well and work with my windstar fan setup. Price was right at $99 with free shipping from Advance Auto.
On a positive note got the rear half of the exhaust loosely mounted. Went with the Pypes 3 inch with X Pipe and Race Pro Mufflers, fits good so far and looks to be a good quality exhaust.
Old May 31, 2014 | 12:32 AM
  #122
johnnyjaws's Avatar
if ur car isn't putting out at least 400hp u wet to big on the pipesize should of stayed with 2 1/4 or 2 1/2
Old May 31, 2014 | 08:35 AM
  #123
bainer1290's Avatar
You bring up a good point I was on the fence 2.5 vs 3, I wanted to have a larger exhaust in case I did more mods down the road. Price was very close on both systems from Pypes...
My build will should deliver around 425hp/500ft lb also.
-Olds 455
-KB 277 30 over pistons (comp around 9.8:1)
-stock rods & crank ground 10 under/align honed/balanced
-Cam 298/306 on a 110, with .568 lift on both (thanks Cutlassefi)
-Comp Roller Rockers/Guide Plates/Studs
-Large Valve 2.07/1.72 G heads light porting job, crossover filled, center divider levelled
-Edelbrock Performer 2151 intake / Quadrajet jetted to match engine
-Hooker Comp non-tuned Headers 3902 / 3 inch Pypes dual exhaust
-HEI Distributor
-TH400 trans, red alto perf rebuild with Transgo 400-1&2
-Rear end is a 3.70 posi
-2,500 Freakshow Performance stall
Old Jun 7, 2014 | 08:47 PM
  #124
bainer1290's Avatar
Got the new aluminum rad in, fits the oem mounts nicely so this should work out well. I need to trim the windstar fan shroud a bit so it fits.
Old Jun 7, 2014 | 08:55 PM
  #125
bainer1290's Avatar
Also mounted up the carb and filter to the intake to see how it looks, I like it!
Old Jun 8, 2014 | 03:13 PM
  #126
bainer1290's Avatar
Got the fan shroud trimmed up, fits real good. Used a Hayden dual fan controller with a adjustable temp control to operate the main fan, then I have a secondary relay wired to the second fan feed which operates the second fan. Lots of feedback out there on how many amps these fans pull, I could not find an actual number anywhere from 15 to 50 amps each is what they say, what I can say is I test ran them for a few minutes each one being fused with a 25amp fuse and 40 amp relay, nothing was hot and ran fine so must be under that.
Old Jul 11, 2014 | 07:22 AM
  #127
bainer1290's Avatar
Well got the engine put together, painted and installed in the car with the TH400. Had the custom 3.5" driveshaft made and have installed it. Put the headers on and also mounted the Alternator and PS Pump.
Hoping to have it running in about a week, just waiting on the correct length pushrods. I also have to finish installing the exhaust from the headers to the mufflers and of course the rad and front end.
Getting close!!!
Old Jul 11, 2014 | 02:28 PM
  #128
Looks good Rob! Sorry I haven't kept up with this thread as I should have. Interesting choice on the cooling system. Love to see how it runs in the summer heat; so I hope your fuse and relay is the right.
I noticed on your engine test fit the headers were black, but on the install they are silver/white? Did you have them ceramic coated or did you just paint them with high heat paint? Sure makes it look easy when there's no rad support to lift the engine and trans over for the install! Did you put a heat shield between the starter and the headers?
Another week to finish? I guess that means you won't be driving this to the Rocket Roundup in Olds this year. No worries, my car won't be there either....sigh....long story for another time.
Old Jul 11, 2014 | 03:08 PM
  #129
bainer1290's Avatar
Hi Allan, no worries I have not been posting as much as I should with updates either!
I just used some Hi-Temp VHT paint on the headers. And yes I have the heat-shield for the starter so we'll see how it does, using one of the oem large starters, it fits with the headers in place but not sure how it will handle the heat, might need to go with a mini starter...
Hopefully only a week to go, which sucks as this weekend (starting tonight) is the Street Wheelers weekend in Lethbridge so I will be drooling all weekend.
Hope your car is doing alright?
Old Jul 11, 2014 | 05:06 PM
  #130
Be prepared for some smoke when you fire that beast up. I don't think the VHT will last very long on the headers.
My car has had its setbacks this year. Right now the garage is in use by a huge stockpile of lumber being used to build back yard projects.
Enjoy the Street Wheelers show. Post some pictures.
Old Jul 13, 2014 | 06:37 PM
  #131
bainer1290's Avatar
Spent most of the weekend in the garage, got the rad in looks good with the electric fans, test ran them for 5 minutes with no issues the 2 relays didn't get hot so we'll see when the engine and rad are hot how it works.
Old Jul 13, 2014 | 06:40 PM
  #132
bainer1290's Avatar
Here's the pypes exhaust, fit pretty good, I installed it then tack welded and then removed to fully weld. Had to weld the mufflers in with them in the car, that was fun.
Old Jul 18, 2014 | 09:10 PM
  #133
bainer1290's Avatar
Got the car running last night, broke in the cam as per the instructions 20 minutes, 2,000 - 2,500 rpm, dumped the oil and filer, all looks good no metal. Got the timing set and the rad/windstar fan setup managed to keep it cool so all looks good no leaks. Next is to get the transmission shifter adjusted, hei/choke are running off the acc terminal on the fuse panel but I think they are not getting enough voltage so I am going to setup a relay from there with a direct connection to the horn relay that way they will get 12v. Spark looks a little weak...
Allan you were right the headers are cooking that paint haha oh well figured that would happen.
The oem starter is weak does not have enough to really crank it good, it starts but not as good as I want it to. Also once its hot its heat soaked and doesn't work for a good 20 or so minutes. Ordered a mini starter from Summit so it should do the trick, wonder if I need to make a heat shield for it?
Oh well should be able to maybe take it for a little cruise this weekend if I get that relay in and the shifter adjusted.
Old Jul 19, 2014 | 01:59 PM
  #134
I thought you had a heat shield installed when you put the headers on. They end up being so close to the starter I'm not surprised you're getting that result. Here's a link to one sold by ILT.
http://www.ebay.com/itm/69-70-71-72-...item257da7e8be
I'm not sure if the OEM starter was different back in the late 60's and 1970 when the engines were higher CR. You've changed your CR from 8.1 to 9.8 so I'd imagine it's going to crank a bit harder. Personally, I'd try installing a heat shield before spending a lot of money on the mini starter. Increased heat on the starter increases resistance in the coil. I think you'll find this will be true on any starter you install. Best thing is to isolate it a bit from the header tubes. Normal engine heat shouldn't affect the starter unless your engine is running way too hot.
Old Jul 19, 2014 | 03:53 PM
  #135
bainer1290's Avatar
Thanks for that Allan, yes I do have the heat shield on there but I think its a combo of heat and just an old tired starter... I found a new Summitt mini starter on ebay for $110 shipped o the US so have it on its way, should solve my problems.
I was able to take the car for a 15 minute drive today, man it sounds nice, I didn't get too far into the pedal but there is lots there!! It ran real good, still have the Hurst shifter off a bit I need to adjust it before the next ride so I can pull it into 1st. Taking it in for the inspection Monday so should be legit to drive after that.
Old Jul 23, 2014 | 07:08 PM
  #136
bainer1290's Avatar
Well passed the inspection, had a few minor issues, one rear drum was too thin, luckily I had a spare one on the spare rear axle. Also the brake light was on, thought it might be the parking brake but turns out it was the brake prop/combo valve pressure switch. When I bled the brakes it must have thrown the pressure differential valve out of center, I read on another site that sometimes you need to re-bleed the system or standing on the brake pedal hard can sometimes reset it too if there is no air in the system, so I stomped the brake pedal a few times and voila the light went out, guess I got lucky.
Got to take the car for a few good cruises now, runs really well lots of power there. Really happy with how it turned out, thanks to cutlassefi, Smitty, Allan and all of the rest of you that helped me along the way.
Old Aug 10, 2014 | 09:07 AM
  #137
bainer1290's Avatar
Installed the mini starter, took it for a good drive to get it warmed up, then turned the car off and let it sit for a few minutes, started right up after that so looks like the mini starter solved the problem. Car is running really good, now its time to put some miles on it.
Old Aug 10, 2014 | 09:30 AM
  #138
tru-blue 442's Avatar
Old School Olds
Congrats!
New pics of the completed jewel?
Old Aug 10, 2014 | 10:44 AM
  #139
bainer1290's Avatar
Here's some pics I just took today, painting will be part 2 of the project coming maybe next spring
Old Feb 28, 2015 | 09:05 PM
  #140
bainer1290's Avatar
It's been some time from my last update, started to dig into the exterior of the car just before Christmas, stripped it to bare metal and found a few surprises. In short ended up need to put some new metal in both front lower fenders and the rear quarters behind all 4 wheels. Then stripped the entire car down to bare metal just to see what else I had, nothing major but there was a few dents and scrapes so I am glad I did it to know what was all under there.
I also put on a set of Viking front coilovers and rear shocks along with 2 inch BMR rear lowering springs. You can see the difference in ride height in the last picture, overall lowered the car about 2.5 inches. I like the look as it fills the wheel wells and makes it look more like a pro touring car.
Old Feb 28, 2015 | 09:09 PM
  #141
bainer1290's Avatar
Then today I sprayed the 2k primer, next will be block sanding to get it nice and straight before paint. Thinking of a medium/dark blue with black stripes.
Old Mar 1, 2015 | 05:54 AM
  #142
Old School Olds
Looking good. I like the stance as well. Nice job.
Old Mar 1, 2015 | 12:19 PM
  #143
sammy's Avatar
Sammy70 455 Supreme
You have come along way with the car! I am liking the stance too........like the drive on hoist too....
Old Mar 1, 2015 | 12:30 PM
  #144
Rob, x2 on the stance.
Question, to get that perfect gap (flush fender to door) did you end up shimming the lower fender mount to 'stretch' it out a bit? It looks perfect!
Just my opinion but I think black stripes on dark blue or medium blue will get lost in the overall appearance of the car. Would you consider something like white, gold or silver for accent?
How soon till color goes on? You spraying it yourself or having it done?
Old Mar 1, 2015 | 12:45 PM
  #145
cdrod's Avatar
Rodney
I like the stance too! I like that it's not too low, your stance seems more practical for everyday driving. What size wheels and tires do you have on the car right now?
Old Mar 1, 2015 | 02:37 PM
  #146
Car is looking real good, great work. What temp does it idle at on a hot day with your cooling setup? I have the same radiator and run a flex fan. On really hot days it will creep up a little higher than I like. So I might try that fan setup on mine.
Old Mar 2, 2015 | 12:06 PM
  #147
bainer1290's Avatar
Thanks for all the comments guys, I am getting excited to see how it looks with color too.
I just got the hoist in the fall, wish I would have sooner as it has made everything way easier!!! Only problem with it is the header collector flanges are a bit low so with the lowered suspension getting on and off I need to use a 2x10 for the front wheels, it doesn't help that my garage has a ramp coming into it too but it works, only really need to park on it to work on it anyways...
I did put a small shim under the front fenders to get that gap just right along with putting an object in the gap while tightening the fender bolts to make it stay gapped form the door.
I thought about white stripes, but not sure I want to go that bold, I was also on the fence about no stripes but think the black would be a middle ground. Just 2 hood stripes, nothing on the sides.
Color hopefully in April/May is the plan, I have a friend that works in a shop and I plan to use him to spray the actual color/clear, I am not that good yet.
15 inch rims, rears are 275/60's and fronts I think 235/50's or 60's. One day I will get 18's or maybe 20's on the rears with 18's on the front, but the budget doesn't have room this year.
The temp has been good, I have the fan control set to 180 and it keeps it within 10 degrees according to the temp gauge, the rad fit really well and the fas setup has worked good too. I am located in Canada so summer temps get up to 100 on really hot days but not usually much more than that so depends what kind of heat you are in I have not tested it in super hot over 100 degree weather...
Old Mar 3, 2015 | 06:53 AM
  #148
bainer1290's Avatar
Allan, you got me thinking of silver stripes now... might look good. The color that I am going with with be similar to this for the blue and it will need to be painted with a silver prior to for it to get the right color so that would be less work painting to go silver vs black.
If I can match the silver/gray to the rims I want to but that might look really good.
Old Mar 3, 2015 | 06:56 AM
  #149
Fantastic color choice Rob. I think with that one I wouldn't even bother with stripes, it looks gorgeous all on its own!
Old Mar 3, 2015 | 06:59 AM
  #150
bainer1290's Avatar
That is a possibility too, there is just something about the stripes that I like.
Old Apr 15, 2015 | 07:00 AM
  #151
bainer1290's Avatar
Well getting closer, the painter is booked for mid May. I blocked it, resprayed it with another 2 coats of 2k primer and am in the process of blocking it again just to make sure its nice and straight.
Color choice has changed a little, now going with the blue below and this gunmetal grey for the hood stripes. Getting excited to see it with some color!!!
Old Apr 15, 2015 | 07:10 AM
  #152
Oldsmaniac's Avatar
Great work, nice project!
Old May 24, 2015 | 06:47 PM
  #153
bainer1290's Avatar
Got the car back from paint on Friday! I love the color, I took a few different pics as the blue changes depending on how sunny it is. Stripes on the hood are done in gunmetal grey and they turned out real nice too, plan was to get some larger rims down the road and maybe match them to the stripes.
Old May 24, 2015 | 07:03 PM
  #154
Very nice Rob! Now for the finishing touches and you're golden.
Old May 24, 2015 | 07:35 PM
  #155
sammy's Avatar
Sammy70 455 Supreme
X2, very nice! I like the stripes also
Old May 25, 2015 | 04:23 AM
  #156
cdrod's Avatar
Rodney
Looking good!
Old May 25, 2015 | 05:00 AM
  #157
Nice, nice, nice!!
Old May 25, 2015 | 06:48 AM
  #158
oldsmobiledave's Avatar
nice work
Season Opener in Medicine Hat next weekend. Get it ready!!!
looks good. I look forward to seeing it in person.
Old May 25, 2015 | 06:53 AM
  #159
bainer1290's Avatar
Thanks guys! Yes I heard about Med Hat, not going to make it this time as we have other plans next weekend but I will definitely have it ready for Street Wheelers in Lethbridge.
Old May 25, 2015 | 07:25 PM
  #160
Fyi
The Lethbridge Street wheelers have the track on June 5-6 for Power to the Pavement. Can you make it to that event?
http://www.streetwheelers.com/power-2-pavement
