1971 cutlass questions??
Old Oct 17, 2008 | 02:43 PM
mildetfan's Avatar
Looking to find some information on my 1971 cutlass.
It's for sale, and the people calling are saying that a 71 didn't come with a manual 4 speed transmission.
Did a 71 Cutlass come standard with a 442?
How do you tell the difference if it's is a 350 rocket?
VIN# 336871M121775
Dennis
Old Oct 17, 2008 | 03:09 PM
Actually the factory specs / dealer ordering show that Cutlass was a standard transmission car unless you upgraded to automatic. But it was a 3 speed standard.
Most Cutlass models came with a TH350 or TH400 automatic Transmission depending on engine. All models could be ordered with optional engines and the 4 speed manual.
If you've got one with a 4 speed, you probably have a nice car with a 455. Also so it was probably a special order car because not many were produced with the 4 speed. Some of the other guys on this site can probably give you more info on your car. Can you put some pictures up so we can see it?
The VIN coding you have means:
3 = Oldsmobile division
36 = F85 Deluxe (also might be part of 442 designation I think)
87 = 2 Dr Holiday coupe (body style no pillars on door or quarter glass)
1 = 1971 model year
M = Lansing (production plant)
121775 = production sequence.
Old Oct 17, 2008 | 07:10 PM
Allan has come close on decoding the VIN, but not quite. 33687 is a Cutlass S Holiday Coupe. In 1971, the F-85 model name was only used on four door cars. It is not a 442, since for 1971 that was a separate model with a unique VIN. The engine code is not included in the VIN for 1971, so you can't tell what engine was in the car originally from the VIN (though you CAN tell that the car was originally a V8 car and not a six cylinder car from the VIN).
The base transmission for this model was a three speed Saginaw manual trans with column shift. Optional transmissions were the HD three speed with floor shift, four speed with floor shift, and three speed automatic.
By the way, if by "Did a 71 Cutlass come standard with a 442?" you mean the engine size, there was never a 442 cubic inch engine offered by Olds.
Old Oct 17, 2008 | 07:20 PM
88 coupe's Avatar
Junior Member
Originally Posted by mildetfan
........ How do you tell the difference if it's is a 350 rocket? ........
As opposed to a "regular" 350? There is no difference.
The term "Rocket" was a marketing term, originally used to keep the public from confusing the 303 Olds with the 331 inch Cad that was released at the same time.
........ there was never a 442 cubic inch engine offered by Olds.
Or a 442 horsepower engine.
Norm
Last edited by 88 coupe; Oct 17, 2008 at 07:41 PM. Reason: added the second reply.
Old Oct 18, 2008 | 12:08 PM
mildetfan's Avatar
71 cutlass 350 4 speed
http://milwaukee.craigslist.org/cto/875378663.html
The upload keeps failing.
Old Oct 18, 2008 | 12:18 PM
mildetfan's Avatar
Thanks for all the information. We really appreciate it!
From what we pulled off the engine it is a 350 and it does have the aluminum trans that everyone calling was asking about.
We've owned the car since 1985 and haven't had the time or money to get it restored. Now, before putting it back in storage we thought we would try & sell it.
Old Oct 18, 2008 | 01:36 PM
I don't know who all was asking, but the only four speed ever offered in a Cutlass was the aluminum Muncie. The cast iron Saginaw four speed was never a factory option.
Old Oct 19, 2008 | 07:22 AM
Originally Posted by Wireman134
Hello, can't you tell if the engine is matching like the 1970 models?
The question was about determining the engine from the VIN.
Old Oct 19, 2008 | 02:05 PM
88 coupe's Avatar
Junior Member
........ If the casting number matches the model year ........
Not likely, if the same casting number was used from '68 to '76.
Norm
Old Oct 19, 2008 | 02:37 PM
Chumley's Avatar
Boy talk about your apples and oranges! I think there is some confusion here as to block casting number, engine size and vehicle indentification number. Everybody is correct, just not on the same page.
Chumley
Old Oct 20, 2008 | 01:16 AM
88 coupe's Avatar
Junior Member
Originally Posted by Chumley
........ Everybody is correct ........
Since, in this case, the casting number has nothing to do with the VIN,
how can both of these statements be correct?
Norm
billybob09
Jun 1, 2014 07:30 PM
grantpo
Ninety-Eight
20
Apr 5, 2013 06:25 AM
dallasite21
Feb 19, 2012 12:25 PM
dsolomon
Jun 23, 2011 08:00 AM
dilges1
Nov 3, 2010 05:45 AM
