1965 Cutlass Manual Steering Question
I've had a lot of sixties GM cars. They've either had power steering, or I've put it in before driving them. I'm wondering what my 65 Cutlass will be like to drive if I just leave it stock with the manual steering.
Can anyone speak to this issue from experience?
I have a 65 cutlass 330 4 speed that came with just power drum brakes. I had the front end rebuilt and aligned. Car drove and steered fine. Steering gear box was a little loose, but still very easy to drive. At take off making turns ,it was a little hard, but with stock steering wheel it did fine. A year or so later I did put power steering on the car because it made it easier for my wife to drive with the 4 speed. I feel better about buying the car since she can enjoy driving it. Hope this helps . Bassinguy
The effort isn't the problem - it's the ratio. Manual steering boxes are way more turns lock to lock, and so going around a corner is like driving a bus.
Try it and see whether it bothers you. Maybe it won't. Drove me crazy.
On the other hand, my 62 F-85 wagon has manual steering and brakes, and while admittedly it's about 1,000 lbs lighter than the later cars (and the aluminum 215 sitting over the front wheels vs. an iron 455 helps a lot), I have no problems driving or steering it.
i have a couple big pontiacs with 4 speeds and manual steering...i learned a long time ago..if you want to live with it, from a stop...the car needs to be moving before ya start turning..it doesnt take much...if i want to make it easy on myself..i just remember the rule
my cars are 4300+ pounds id guess...and no big deal..just keep it moving...and i love them both the way they are...
Bobac455
February 6th, 2014 02:04 PM
Eightupman
January 6th, 2010 03:14 AM
