weird tool - what is it for?
Old Oct 5, 2014 | 11:33 AM
Octania's Avatar
http://i19.photobucket.com/albums/b1...&1412533916967
Not the 1/4" drive socket, the other thing
1/4 hex shank, 90' bend, then 1/4 socket drive end
What possible purpose can this have?
Bought via Grainger I think
IMG_9723_zpsee1167c6.jpg?1412533915575&1412533916967
Old Oct 5, 2014 | 12:47 PM
I dunno, maybe for accessing tight clearances?? Or is this one of your riddle of the day things?
Old Oct 5, 2014 | 12:50 PM
boese1978's Avatar
specialized tool that probably came as an "assembly tool" in some kind of kit?????
Old Oct 5, 2014 | 02:40 PM
A key adapter for some kind of tool. like a lathe chuck?
Old Oct 5, 2014 | 04:49 PM
RandyS's Avatar
It's as simple as it looks. It is a right angle adapter for small socket set without a ratchet. Comes with a handle like a screwdriver to use staight with various sockets, driver bits, etc. Use the RA adapter for added leverage.
Old Oct 5, 2014 | 04:54 PM
Sugar Bear's Avatar
May be a hex head designed for different leverage sources. One could put various length 1/4" extensions on it as the lever.
Snap-on makes a ratchet head in a similar fashion. It is flat without a handle, 3-4 inches long, and a 3/8" extension of any length may be put into to vary the leverage and its ability to fit into limited access places.
Old Oct 12, 2014 | 08:25 AM
442Harv's Avatar
It is just what it looks like it is. I had one and it works so good for hard to get at small screws, like under the dash, where you can't see, or get a ratchet on the screw, because of no room. It gives you some leverage. I had a complete small socket set with one in it. I lost it years ago, and have not found another one. Would like to hind another one.
Old Oct 12, 2014 | 02:38 PM
m371961's Avatar
Looks to me like someone put a 1/4 drive drill adapter in a vice, heated it and bent it.
Old Oct 12, 2014 | 03:28 PM
Bfg's Avatar
Bfg
Looks to be a special tool to remove the flux capaciter on a early Olds!
Joeypete
Aug 17, 2009 09:39 AM
HurstOlds1775
May 7, 2009 05:09 AM
cisco88
Jul 6, 2008 04:03 PM
chadnum1
Apr 30, 2008 11:12 AM
1BAD68"S"
Brakes/Hydraulic Systems
Nov 17, 2006 04:20 PM
