Break into your garage in 6 seconds?
Old Feb 15, 2014 | 07:47 AM
Tom442's Avatar
My cousin sent these links to me...easier for the thieves to see the emergency latch if you have windows on your garage door. The fix...a zip tie as seen on the first link. Going to grab a zip tie now!
Tom
Old Feb 15, 2014 | 03:36 PM
RROLDSX's Avatar
Doesn't matter, you can just wrench on the door to over come the safety ratchet system in the electric door opener anyway. That's the system that stops and ratchets the opening mechanism to avoid squishing infants. I have removed my door openers completely. I run a bolt through the track and into the wheel housing to lock it. Of course my garage is my shop and I don't park my daily driver in it. If the spring mechanism that lifts the doors is adjusted properly, t'aint nothing to lift the door manually anyway.
Old Feb 15, 2014 | 03:39 PM
RROLDSX's Avatar
At least now I know why all the scratch marks are now in the top trim in the middle of the door are caused by now.
Old Feb 15, 2014 | 04:32 PM
spf1410's Avatar
Yep... had somebody try to get into mine that way. Lock/bolt in the track kept them out and away.
Old Feb 15, 2014 | 06:17 PM
don71's Avatar
same but different
Thanks for that story. I've not seen a solution that easy since I first heard of this problem.
The bolt idea is a good one. If you don't feel like getting out the tools, use a C clamp, fast and easy.
When thinking of security, don't forget about your front door, Or any door. Lock bumping is scary
Old Feb 16, 2014 | 08:32 PM
OLD SKL 69's Avatar
GM Enthusiast
I used a heavy duty slide latch on the top side of the garage door frame. I can slide it over and even put a lock on it. Can't open the door with it in the way.
Joffroi
Jun 14, 2013 08:37 AM
jack69cutlass
Oct 23, 2012 09:56 AM
BIGJERR
Aug 9, 2011 05:40 PM
BIGJERR
Jul 18, 2011 06:12 PM
skubydobdo
Aug 18, 2008 03:32 PM
