pilot bearing grease
Old Feb 7, 2016 | 09:10 AM
Railguy's Avatar
I m putting a new clutch in my John deere 750. Can anyone tell me what kind of grease to use on the pilot bearing. Also the pilot bearing has a holder that rides on a input shaft/pilot shaft. Unlike other transmissions I ve seen. Is there a grease for this. As you getting to the pilot bearing requires taking the tractor in half.
Railguy
Old Feb 7, 2016 | 10:48 AM
1970cs's Avatar
Lansing built
I am not a Deere expert. But usually the pilot bearings were also sealed on both sides. Now on the outer tube where the throw out bearing rides on, you may use some grease gun grease.
Pat
Old Feb 7, 2016 | 12:00 PM
Railguy's Avatar
I guess it s a pilot bushing . Some people say to use high temp grease some say the bushings are self lubricating and adding grease will clog them up. I don't know when they started using the self lubricating ones I have heard of them . The manual I have for the tractor doesn't say to grease them but it doesn't say not to .
Railguy
Old Feb 7, 2016 | 12:06 PM
marxjunk's Avatar
they are self lubricating if a bushing..just a touch is all thats needed and thats so it will slide together...put a pea size drop of high temp grease on your finger and rub on the input so it slide together..just a touch it doesnt take much..it burns off almost instantly..
Old Feb 7, 2016 | 01:09 PM
Railguy's Avatar
I think this is a 1979 did they have the self lubricating ones than?
Railguy
Old Feb 7, 2016 | 02:49 PM
If its a bushing (oilite), they are oil impregnated, no grease needed.
Old Feb 7, 2016 | 03:08 PM
marxjunk's Avatar
they had self lube all the way back to the 20s
Old Feb 7, 2016 | 06:00 PM
Yellowstatue's Avatar
And then there is always the interrogation of your local John Deere dealer.
Old Feb 8, 2016 | 06:04 PM
Railguy's Avatar
The manual does say to use a light grease.I missed it because it said it in the part that explaned how to disassemble it which I glossed over. Which I shouldn't have done but it is kinda backwards. BTW it wasn'tself lubricating.
Railguy
Old Feb 13, 2016 | 07:13 PM
Railguy's Avatar
Got it back together took about 7 hrs would have been easier with a cherry picker instead of chain over the rafters.
Railguy
rothlane'68
Nov 29, 2015 06:54 PM
ROBZ442
Mar 2, 2011 08:13 AM
Aceshigh
Jan 27, 2011 04:28 PM
4-Speed
Jul 17, 2010 08:30 PM
MN71W30
Jun 28, 2009 12:03 PM
