This hurts.
Old Nov 15, 2011 | 08:22 AM
rocketraider's Avatar
Oldsdruid
This hurts.
This justifies your purchase of a $20 fire extinguisher for each of your old cars.
http://www2.godanriver.com/news/2011...le-ar-1459479/
I've known this car for years. It belonged to an elderly neighbor lady and I washed it and took it in for service for her many times. Present owner bought it from her estate and had maintained it nicely until now.
The way the interior's burned, makes you think wiring like Jamesbo's Hurst. But I wouldn't hesitate to bet ethanol-laced fuel might have contributed.
Old Nov 15, 2011 | 08:38 AM
That is sad!
Old Nov 15, 2011 | 11:18 AM
citcapp's Avatar
Add scary to sad.
Old Nov 15, 2011 | 11:24 AM
oldsguybry's Avatar
NOVICE car nut
that sucks ..... I have a small fire ext. in my car and my version of quick disconnects on the battery .... I can have the battery cables off in less then 10 seconds
Old Nov 15, 2011 | 01:20 PM
Want to bet that most don't have a FE in their car? If you do, the best one is a CO2 because it does the job and doesn't contaminate any harnesses it touches. Course a fire doesn't discriminate on burning wires so it's really the owners call.
Don't forget: FE's must be checked and recertified periodically. Check your local fire codes for those dates. I believe refills are every 3 years, and tank recert is every 6.
Old Nov 15, 2011 | 02:07 PM
Railguy's Avatar
The worst part would be having to watch it burn.
railguy
Old Nov 16, 2011 | 12:00 AM
Rocket Richard's Avatar
I can relate to that. My 78 VW beetle caught fire in the engine bay while I was driving. By a stroke of luck it had been raining the day before, and there was a ditch beside the road. A good samaritan stopped and used his lunch cooler as a bucket to scoop up water and put the fire out. The car was saved. I was VERY lucky.
I do carry a fire extinguisher now, and when working with fuel lines etc. I put a lot more thought into safety.
Old Nov 16, 2011 | 04:41 AM
67 442's Avatar
One part at a time
I have a FE in the back passenger floorboard of my car. I get the odd look when friends see it but I am not taking any chances. I also disconnect the battery when I know I won't be driving it for a while.
Old Nov 16, 2011 | 11:56 AM
Redog's Avatar
It there a speical FE you need to keep inside a car? One that won't explode and have the CO2 leak out? Or just a regular one from Home Depot will do?
Old Nov 16, 2011 | 12:27 PM
morepwr's Avatar
I have one in my old cars but I dont have one in my daily driver truck.
Thats probably not very smart and I should get one for it too.
Old Nov 16, 2011 | 07:15 PM
oldsonharmont's Avatar
Absolutely frightening! Have they determined the cause or origin of the fire?
Mar 18, 2014 03:29 PM
Roger Thibodeau
Nov 1, 2013 08:29 PM
Crusty
Jun 19, 2013 06:54 AM
lem47
Aug 14, 2012 08:44 AM
64Olds98
Aug 6, 2010 03:35 PM
