European power convertor
Old Mar 28, 2015 | 07:28 AM
My son is going to Spain this summer for some classes and needs a way to charge his phone and laptop. Can anyone recommend and provide a link to one that's reliable and handle the task?
Old Mar 28, 2015 | 02:47 PM
jaunty75's Avatar
Check the AC adapter for the phone and computer. They're very international these days.
It very likely says on it "AC Input: 110 - 240V, 50-60 Hz." If it does, all you need is an adapter to plug a U.S.-style plug into a European-style outlet. You don't need a power inverter or converter or anything else. The phone/computer AC adapter can already work with European voltages.
If the adapters do say as above, all you need is something like this:
Here's a six-pack of them for $7.00 at Amazon.
Amazon.com: Ceptics USA to Europe Asia Plug Adapter High Quality - CE Certified - RoHS Compliant - 6 Pack: Electronics Amazon.com: Ceptics USA to Europe Asia Plug Adapter High Quality - CE Certified - RoHS Compliant - 6 Pack: Electronics
If you live near an airport, the travel stores in there will likely have them, and Radio Shack might as well if there are still any in your area.
Old Mar 28, 2015 | 03:00 PM
jaunty75's Avatar
If, in fact, your son's AC adapters don't accept dual voltages, it would probably be cheaper to just buy dual-voltage adapters for his phone and/or computer, and then he wouldn't have to lug around the power converter wherever he goes.
Old Mar 28, 2015 | 04:34 PM
... Or just buy a charger over there once he gets there. Most cell phone, etc. chargers are darned near as cheap as adapters these days.
But, yeah, Jaunty nailed it already. If the tiny print says it will work on 240V / 50hz, he's all set, and if not, Hey - they make appliances over there, too.
Old Mar 28, 2015 | 04:40 PM
Yeah Eric, but I don't want him to release the smoke out of his working ones. Thanks guys.
Old Mar 28, 2015 | 04:52 PM
But my point is that when you travel, it's best to avoid packing things you don't need, like chargers that don't work on the local current (or that need adapters) - the average $5 charger that you buy at the hardware store or the 7-11 will last a couple of months - just long enough to get through a summer - so he may as well just buy some cheapo ones over there and save the packing space for more important things.
Old Mar 28, 2015 | 04:58 PM
Point well taken.
Old Mar 28, 2015 | 08:43 PM
steverw's Avatar
My cell phone and laptop chargers came with dual voltage chargers. When I went to China all i needed was an adaptor, think I bought it at Wally world. Worked like a charm.
Steve
Old Mar 30, 2015 | 02:33 AM
rustyroger's Avatar
'87 Delta 88 Royale
What is the output on the adaptor he uses right now?. All he will need is one with the same output.
I believe the plugs on the chargers are shaped so only the correct voltage one will fit anyway.
Roger.
Old Mar 30, 2015 | 12:23 PM
Seff's Avatar
...Does that mean stuff charges twice as fast over here? :3
Old Mar 30, 2015 | 02:10 PM
Watts you say...
I think I've got a handle on it now. Thanks for all your responses I was confused on how modern chargers work.
C.M.D.
Apr 29, 2015 02:28 PM
Seff
Apr 19, 2011 09:16 AM
Jamesbo
Dec 19, 2009 05:05 AM
Redog
Nov 16, 2007 05:52 PM
handsomened
Mar 29, 2007 03:00 PM
