distributor vacuum control switch
Hello , have a 72 olds cutlass with a bad/broken DVCS and car wont shift out of first gear can i bypass? also did a intake, carb, distributor swap edelbrock..so any suggestions would like to keep oem part if any one has one for sale that would be great
I don't think it works that way
Your trans should get manifold vacuum from the manifold directly, not thru any sort of switch.
If you are talking about that thermal sensitive three nipple [possibly with electrical connections 70-72] device at the front of the intake.... please describe what you think that item's function is and how it is [should be] connected.
I believe, from past experience, that if the vacuum hose to the trans modulator valve [RH side, where the vacuum hose is] gets disconnected, you will experience no shift until a very high RPM. With all the work you did, I would say this is a good possibility, and certainly easy enough to check at the trans. If the hose is still on, pull it off and verify that it has manifold vacuum when the engine is running.
+1. DVCS has nothing to do with shifting (or with anything important at all, really).
Check your modulator hose to be sure it's connected properly, both top and bottom.
If it is, then check inside for the presence of ATF - if it's there, your modulator's shot.
If there's no obvious ATF, suck on the engine end of the line. You should be able to pull and hold a vacuum (no leaks).
If that works, then try it again with the lower end of the line disconnected from the modulator - if you can still pull a vacuum, then the line is blocked.
Welcome to ClassicOlds.
oh damn that was a really well summarized troubleshooting procedure for the vacuum feed to the modulator.
While it is possible for the modulator to fail w/o leaking ito the vacuum line it is extremely unlikely and an incorrectly connected modulator vacuum line is far more likely.
Did you mess with/upgrade anything else? It could be your kickdown cable that runs from the accelerator pedal to the trans. Make sure it's adjusted properly and not sticking.
I deleted my DVCS with no ill affects.
transmission switch
the electric connection on top of the Dvcs what should i do with this if i by pass i was reading in the service manual cd that i just got today that it hooks up to the transmission switch? do i leave it alone maybe tape it up ? and thanks for all the input guy im still learning ....
ddd777
April 10th, 2013 05:55 AM
