Chevy engine block; bring a chainsaw
Old May 14, 2011 | 10:00 AM
Mark71's Avatar
Talking Chevy engine block; bring a chainsaw
This ad is too funny. I found it on Craigslist here and thought you guys might get a kick out of it.
The price seems a little high because you know it is going to need some machining prior to rebuilding.
http://delaware.craigslist.org/clt/2379137445.html
Old May 14, 2011 | 10:14 AM
If it really is a 1967 302, it's probably worth a bunch. And let's not forget that back in his drag racing days, Jack Roush used to bury brand new block castings in the ground for a year to stabilize them prior to machining.
Old May 14, 2011 | 12:38 PM
And who said those things don't grow on trees...?
Old May 14, 2011 | 01:55 PM
oldsguybry's Avatar
NOVICE car nut
I wonder what else is in that tree
Old May 14, 2011 | 05:48 PM
redoldsman's Avatar
Proud Viet Nam Veteran
That is crazy. If I remember correctly, those were referred to as DZ blocks. As Joe said, it is worth a lot. There are a lot of early Z28's out there with 350's in them after the 302's were blown.
Old May 14, 2011 | 06:09 PM
Aceshigh's Avatar
It WAS worth alot......
Until someone "Broke the casting # off".
That's pretty cool though.
Old May 14, 2011 | 07:37 PM
compedgemarine's Avatar
actually it is not worth much as that casting number was used for the 302, 327 and 350 engines. the only way to know it for a 302 Z-28 is to look at the vin pad (which is not visible) and see if it is stamped with a DZ.
Old May 14, 2011 | 08:27 PM
GAOldsman's Avatar
"Car"mudgeon
X2
Old May 19, 2011 | 08:38 AM
Warhead's Avatar
Good stuff!
Jim
Old May 19, 2011 | 08:53 AM
Oldsguy's Avatar
Past Administrator
Wonder if the heat would ruin the temper in the steel if they burned the wood off the block. Not sure how hot it would burn, if it would be enough to anneal the steel.
Old May 19, 2011 | 09:36 PM
Mark71's Avatar
Usually, the trees don't hold on to their blocks so tightly. In fact, towards the end of fall, the large blocks get so heavy, they usually just start falling out. If you're willing to wait you can buy a sapling at Home Depot and in a few short months it'll start producing small blocks. For big blocks, though, the wait's a little longer.
But seriously, don't get the wrong impression of Delaware. We're not all raving hillbillies with engines stuck in trees and whatnot. I mean, I am, but most of my neighbors aren't.
Old May 19, 2011 | 09:45 PM
442much's Avatar
Oh good God! And here I was thinking that everyone was trying to save the tree.....
Old May 19, 2011 | 10:14 PM
stevengerard's Avatar
I hope they looked under the stump for the rest of the car
Old May 20, 2011 | 05:34 AM
GTI_Guru's Avatar
Certifiable car addict...
I've heard of Iron Wood trees before, and I've seen trees that ate things over the years, but wow. That's impressive. Too bad they had to cut her down. That tree did everything in its power to survive. Good stock there. Should have grabbed some of the saplings that had started to take root nearby.
Old May 20, 2011 | 01:52 PM
Well, first, it's not steel, it's cast iron (as in cast iron wood stove), and second, it's not heat treated so there's no temper to lose. Until the last decade or so, most cars used very little in the way of heat treated steel other than springs and bolts. Frames, suspension parts, body panels were all mild steel.
Old May 20, 2011 | 03:40 PM
66luvr's Avatar
Dz, 69 302
mo, 68 302
mo, 67 302
mp, 67 302 w/a.i..r.
Railguy
Jan 20, 2015 05:41 PM
mmurphy77
May 29, 2011 03:13 PM
Lady72nRob71
Dec 30, 2010 06:38 AM
WTony
Jul 13, 2010 09:42 AM
skubydobdo
Oct 31, 2008 05:30 PM
