Ariens Snowblower Issue
Old Nov 28, 2014 | 12:29 PM
My442's Avatar
Question Ariens Snowblower Issue
I have an Ariens 824 snow blower.
It starts and runs fine, EXCEPT:
The key switch will not turn it off. Have to pull the plug wire.
The key switch tests fine with an ohm meter.
Any ideas?
Old Nov 28, 2014 | 12:50 PM
stan 65 cutlass's Avatar
follow the wire, it must be broken somewhere, my chainsaw is the same. broken kill wire
Old Nov 28, 2014 | 12:52 PM
CutlassDad's Avatar
The switch should have continuity when off, and be open to run.
This is a mag ignition, right?
Old Nov 28, 2014 | 01:55 PM
RetroRanger's Avatar
72 Olds CS
The wire should run down to the base of the engine where it connects to a male spae lug. The switch I believe grounds thru it's mounting so if the wire is good and connected clean up where the switch mounts....iir I will snap a pic at my moms she has an Ariens w that setup, mine is a little different where the throttle incorporates the kill switch. Btw since it's a mostly vintage car forum mine is a 1971 ariens I've owned for the last 23 yrs, my moms is a new one 1979, I picked it up for her when her 1983 ariens one wore out after only 26 yrs....they just don't make the new ones a robust as the older ones lol
Old Nov 28, 2014 | 09:25 PM
I mentioned my new snowblower woes in another thread, gave my 27 year old Toro away after buying a new Snapper two years ago, what a mistake!
Old Nov 29, 2014 | 03:53 AM
I wish I hadn't left my '59 SnowBoy (OMC / LawnBoy company) at an old house - that little thing was no powerhouse, but it was just a crazy little monster.
As for the Ariens, yeah, it should be a simple kill wire, it will go to the coil, and there is a broken connection somewhere. Easy fix, or just close the throttle with your finger when you're done using it, and hold it 'till it stops (it'll be a little spring-loaded tab on the carb connected to the governor inside the motor by a stiff straight wire).
Old Nov 29, 2014 | 07:00 AM
Macadoo's Avatar
I bought an Ariens riding mower last year. What a piece of junk. Within a week the parking brake was broken, and the float was sticking. I should have taken it back but thought fixing would be easier.
1yesfan
Aug 4, 2015 06:40 PM
Dead Reckon
Jul 14, 2014 02:35 PM
TedH
Jan 23, 2009 07:42 AM
TWS
Jan 10, 2009 02:50 PM
boylost
Aurora
Aug 29, 2006 06:46 AM
