1972 Cutlass tilt steering wobble
Old Jun 7, 2014 | 09:17 PM
oldjunk's Avatar
Hi there,
I have a 1972 Cutlass with tilt steering. It is wobbling like crazy, to the point it sometimes goes out of gear (automatic on the column). Is this an easy fix? Anyone have directions? Do I possibly need a different steering column? Thanks for any help.
Old Jun 8, 2014 | 06:19 AM
billmerbach's Avatar
major noob
You're in for a treat on this one. I believe you have to remove the wheel and all innards down to the yolk that allows it it tilt up and down. There should be some funky headed bolts on my dads gran fury it was E10 I'm not sure bout olds tighten those down and you're wheel should be as right as when it rolled off the showroom floor
Old Jun 8, 2014 | 06:43 AM
tru-blue 442's Avatar
Old School Olds
If I remember right,
there is a caged ball bearing
unit down there that has
probably lost most or all of
its ***** down in your column.
The easiest fix is to find another
column. IIRC, they are a pita.
If you have access to a CSM,
you can see what is involved.
Old Jun 8, 2014 | 09:59 AM
69ishHoliday's Avatar
I had the same problem with a Camaro many years ago. I pulled the steering wheel and some other parts and found some loose bolts that needed tightening. I don't recall the process as being a big deal at all and it was done without any special tools other than I think a generic wheel puller. - Steven
Old Jun 8, 2014 | 04:27 PM
Originally Posted by oldjunk
Hi there,
This is extremely common on the GM tilt columns. Here's a detailed web site with instructions and great pictures.
Old Jun 8, 2014 | 06:26 PM
oldsguybry's Avatar
NOVICE car nut
Yes , I had a Regal that the tilt locked up on , and WOULD change gears if you tried to turn a corner ...... A right turn = The car shifting into 1st gear .... A left turn = The car going into park .... or reverse .
Old Jun 8, 2014 | 06:42 PM
oldspackrat's Avatar
Joe,
Thanks for that link!
Old Jun 8, 2014 | 08:12 PM
oldjunk's Avatar
Thank you for the help everyone!
CutlassS1972
Apr 13, 2015 04:37 AM
kona0197
Dec 16, 2011 10:52 AM
sammieolds
Aug 10, 2010 02:49 PM
76Supreme350
Apr 16, 2010 08:01 AM
Lady72nRob71
Suspension & Handling
Jul 6, 2009 05:31 PM
