convert frames
convert frames
i just broght some convert, frame rails and i am getting them placed on my , hard top frame and, i just nocticed that i have a option for more body mounting , and i was wandering would i need any kind brace for proper mounting,would any one have photos , of their convert and mounting , placement. here is the progress on my project, {thanks brian trick} 496 olds w -30 project 034.jpg
The major strength of a normal vehicle is mainly in the roof structure,as this keeps the whole frame from flexing.
If you notice today's cars,the strength has been moved to the front pillars...you will notice how thick and solid they are.
Convertibles NEED a boxed,heavier frame to keep it's body integrity.
Welding frame rails to your hardtop should be a no brainer...it shouldn't really matter as long as the welds are done correctly...as you still have your roof structure.
When you use the convert frame rails, you should also use the convert trans cross member...you might notice that the hardtop cross member is longer on the ends
Vista Cruiser uses the same rails and cross member as the convert.
Last edited by Yellowstatue; Apr 21, 2012 at 03:09 AM. Reason: Stuff caught in corner of mind.
Note that for 1964-67, you could actually get the boxed convert frame under a hardtop from the factory by selecting the Heavy Duty Frame option.
On 66-7 all body mounts go into the main frame, not the convertible boxing pieces. I am not sure about all other years, but suspect the same is the case. When adding the boxing parts, be sure they are slid over the original frame C sections the right amount, and the spacing is correct so the crossmember will bolt in, and have the transmission mount pad located correctly.
the big picture ,of this build will have 4 inch exhaust , so the cross member will need to be modified,and the motor is going to set back a little . this will be a gasser/drag car,.
vistacruiser1971
Nov 9, 2013 01:19 PM
