Proper sequence to reinstall grills/headlamps/etc 72 442?
Old Nov 16, 2011 | 08:55 AM
skryla's Avatar
Right now the fenders are on with a bare radiator support. What sequence should I reinstall the headlamp buckets, headlamp surrounds, grills, latch support, etc.
Any pitfalls I should look out for? The grill mounting into the stoneguard looks like it could be tricky.
Any and all comments/stories/suggestions would be greatly appreciated. I'd hate to break something or have to assemble/disassemble/reassemble and waste time as it is at a premium right now.
Thanks in advance....
Old Nov 16, 2011 | 09:31 AM
Lady72nRob71's Avatar
If you have the assy manual, one might be able to just follow the steps (pages) backwards. I looked at this a few months ago and it APPEARS like it will work........
Old Nov 16, 2011 | 10:47 AM
skryla's Avatar
I have that book but I'd like some "real life" experience. I'd hate to break one of those damn plastic tabs off the grills or housings!
Old Nov 16, 2011 | 11:30 AM
dc2x4drvr's Avatar
I just replaced one of my grilles...be very careful snapping your grilles into the stone guard, hand tighten all bolts, checking alignment as you go, if everything lines up,GENTLY tighten all fasteners. Don't force anything to fit, plastic is fragile. The bigger challenge is fitting the bumper.
Old Nov 16, 2011 | 11:55 AM
skryla's Avatar
do you work from the outward (headlights) in to (stoneguard) or vice versa?
Old Nov 16, 2011 | 12:04 PM
Tony72Cutlass'S''s Avatar
I would remove my bumper, you're saving yourself putting cracks in your stone shield.
Old Nov 16, 2011 | 12:15 PM
skryla's Avatar
Nothing but the fenders on. Here's what I am working with...
Old Nov 16, 2011 | 05:37 PM
skryla's Avatar
No One has any advice?
Old Nov 16, 2011 | 05:59 PM
All I can say is WOW! That thing looks great!
I will be following in your footsteps come spring when i pull all that front stuff off, restore it, and reassemble.
I am wondering if I can even remove the radiator support without pulling the fenders...
Old Nov 16, 2011 | 07:14 PM
70Post's Avatar
Yes - and you can leave the hood on the car as well.
Sorry about the hijack but I saw Rob's question. Just try some test fitting to see which part goes on first. You already know you need to assemble the grilles and stone shield into one piece. With the plastic headlight housings it just depends on how much wiggle room or play you have. My bet is you can mount the grille/stone shield piece first (loosely as far as where it attaches to the nose piece (ie metal part that holds your hood lock relay, etc) and then try one headlight housing.
Old Nov 16, 2011 | 08:13 PM
Fakser's Avatar
Damn thats pretty
Old Nov 17, 2011 | 10:57 AM
dc2x4drvr's Avatar
The holes in the center support are slotted, so I start there, and center the assembly to the hood...
Old Nov 17, 2011 | 12:11 PM
skryla's Avatar
Thanks, that's the kind of practicle applications that the book DOESN'T have!
Old Nov 17, 2011 | 12:12 PM
skryla's Avatar
I'm saving the hood for last as I'm not sure what I'll run into! I haven't started the engine yet.
wcourt3010
Apr 13, 2015 12:10 PM
bwichman
Dec 31, 2012 04:32 PM
miked
Oct 10, 2011 07:45 AM
pcard
Jul 13, 2011 11:55 PM
elcaminodave
Sep 22, 2008 09:13 PM
