Rear sway bar swap
Old Aug 1, 2011 | 12:38 PM
455man's Avatar
Rear sway bar swap
I'd read once that a rear sway bar from an F body 70-81 would fit on an 64-72 A body. Can anyone confirm this. Now that I'm looking I cant find anything that says it's true. Reason I ask is because I found a cheap sway bar for an F body but dont want to get it if it wont fit my car.
Old Aug 1, 2011 | 02:09 PM
Fastbrianman's Avatar
I do not see how it will work. The mounting is totaly different between a leaf spring car and an A body. The center of the bar attached to long links to brackes mounted on the frame rails and then on to brackets on the leaf spring pearch.
I am interested to see pictures if some one has done this swap.
Old Aug 1, 2011 | 06:14 PM
Not even close. The FRONT sway bar from a 1970-81 F-body bolts into a 64-72 A-body (hint: go for the 1.25" version) but no such luck on the rear bar.
Old Aug 1, 2011 | 06:59 PM
jensenracing77's Avatar
you could post in the parts wanted for one from an A body. i think you can get used originals for around $80. "i think"?
Old Aug 1, 2011 | 07:47 PM
TripDeuces's Avatar
What Joe said
Old Aug 2, 2011 | 05:52 AM
455man's Avatar
Cool. Thanks guys. I might have been confused about the front sway bar.
66 Olznut
Dec 7, 2012 11:33 PM
agtw31
Mar 19, 2009 07:49 PM
Olds luvr
Jan 19, 2009 06:35 AM
cola
Mar 15, 2008 03:08 PM
Carleta
Jul 4, 2006 11:44 AM
