1971 Cutlass Supreme: guidance on removing rear window trim
Old Mar 8, 2023 | 09:51 AM
Joe59's Avatar
1971 Cutlass Supreme .. I would like some guidance on removing my rear window trim. It needs re-sealed
Old Mar 8, 2023 | 11:51 AM
There is only one way to remove the trim - get the correct tool. Slide the tool under the trim, snag the trim clip, and rotate the tool to release the clip. And once you get the trim off, expect to find rust, not just bad sealer.
VI Cutty's Avatar
There's a tool for releasing the trim clips, but you can usually make do with a putty knife. Plenty of videos on Youtube demonstrating how to release them.
What needs to be resealed? There's no seal for the trim, just the adhesive used for the glass. If the window is leaking, you're best off taking it to a glass shop to have it dealt with properly, and be prepared to deal with rust in the window frame...
Old Mar 8, 2023 | 11:57 AM
??? How? You have to pull on the clip. Sorry, but just get the right tool.
Old Mar 8, 2023 | 12:09 PM
VI Cutty's Avatar
??? How?
Not very well :-D
Old Mar 9, 2023 | 07:10 AM
Joe59's Avatar
Old Mar 9, 2023 | 10:40 AM
Oldsguy's Avatar
Past Administrator
There are different versions of that tool, I have one that is similar and works well that cost me about $13.00. Well worth it.
Old Mar 9, 2023 | 12:58 PM
Joe59's Avatar
I just picked up a pair of those. Can't wait to try them out.
Old Mar 9, 2023 | 02:48 PM
Oldsguy's Avatar
Past Administrator
If you got the brand that I did be prepared for the rubber on the handles to slip somewhat, not affecting their efficiency but kind of irritating. I ran a drop of cyanoacrylate down between the handle and the grip.
Old Mar 10, 2023 | 01:16 PM
Joe59's Avatar
The windshield molding removal tool worked great.
A BIG THANK YOU GUYS
Old Mar 10, 2023 | 01:36 PM
Funny thing about using the right tool for the job.
Glad that worked out for you.
euroman1959
Mar 9, 2023 07:13 AM
71CS
Feb 8, 2017 04:58 PM
71CS
Feb 8, 2017 07:49 AM
Oldssupreme
Apr 30, 2016 05:48 PM
dhartley72
Jun 26, 2010 12:48 AM
