Frame mount exact location
Old Feb 10, 2020 | 08:53 PM
tkcutlass's Avatar
I have a couple of body mount holes that need repairing
I plan on using https://www.opgi.com/chassis-suspens...it-c21159.html
What is the best way to get them in the exact location for the original ones are rotted/worn out?
this is a replacement frame that I am prepping to send to get blasted and powder coated.
Old Feb 11, 2020 | 08:23 AM
Schne442's Avatar
No it's not a parts car!!
I had to repair 6-7 of the Frame mount holes (72 Cutlass Convertible) after attempting to use Large washers, similar to what you have shown,
I ended up using Plate steel and just cutting out the frame and welding in new steel
I then used a Frame Schematic and measured the Mounting locations and drilled new holes ( measure 10X, cut once )
The Body lined back up with the Mounting locations perfectly
Old Aug 16, 2020 | 08:47 PM
DewChugr's Avatar
Photoshop God
I’m sure you got this by now but I got some washers from fatenal. The ones I used are I. My mud thread in major projects. Hella cheaper.
kevdz79
Aug 27, 2019 05:43 PM
Krom
Jun 7, 2016 07:01 AM
Carsick
30
Dec 10, 2015 07:33 PM
foo
Jun 28, 2012 11:00 AM
sunsetlimited
Jul 27, 2011 08:16 AM
