Tilt steering colum swap?
Let me introduce myself first i have a 70 cutlass
green mist with green interior. 350 4bbl edelbrock rpm intake . I have owned this car now for 7 years would drive it anywhere without hesitation. My name is Scott . NOw the question will a 73 to 75 cutlass tilt steering colum swap into a 72 cutlass? I`m asking for a friend as we stumbled across one in a junk yard. this is for his wife`s car a 72 supreme convertible.
Hi cutlasspeg,
As far as I know, the columns won't interchange. If you are in good with the local salvage guy, you should check his hollander interchange manual. If it won't interchange I may have a column shift tilt. Should even be the right color. It does need the shift handle and tilt and turn signal arms. The last two may work from the later column. Greg drhotwheels@mybluelight.com
70Post
Mar 2, 2015 11:26 AM
