Steering column / rag joint question
Old Oct 13, 2017 | 11:19 AM
nocopo's Avatar
Question Steering column / rag joint question
OK a while back with my header install I had to remove the column ( 66 Cutlass non collapsable column key in dash ) from the steering box at the rag joint. The shaft slid up and now I have a "gap" at the steering wheel and bowl in the car. It also looks like the rag joint is stretched a bit. how do I correct this? It looks like it needs to be slid back or seated back towards the rag joint taking the stretch out of it and closing the gap in the car?
Thanks !
Old Oct 13, 2017 | 12:59 PM
2blu442's Avatar
I know that center shaft can move as it did on your column. I'd try removing the horn button and tapping on the center shaft to see if you can drive it back down the amount you need.
Old Oct 14, 2017 | 06:25 AM
When the shaft slid up in the steering column, the turn signal cancel cam popped up out of the actual turn signal switch. You must remove the steering wheel, remove the cancel cam, and reposition the center shaft first. Install the cancel cam correctly, then reassemble. DO NOT drive the car this way, as it will damage parts in the column (like the unobtanium turn signal switch).
Old Oct 14, 2017 | 05:21 PM
nocopo's Avatar
Smile
Upon further investigation.... The rag joint vs shaft is in upside down the large alignment pin is resting on the flange preventing it from being closer to the steering box, it also explains why I can feel the road sometimes in the wheel. Luckily there is zero damage inside the column. I must have flipped the shaft alignment in the dozen times I took it apart to clearance the headers. Easy fix, just didn't catch it when assembled. Thanks all
mazey
Apr 24, 2017 06:21 PM
joesw31
Sep 24, 2016 07:07 PM
MDchanic
Suspension & Handling
May 22, 2011 09:21 AM
STLCRZY
Apr 26, 2011 11:21 AM
J-(Chicago)
Aug 22, 2009 09:25 PM
