question on interchangeability
Old Jul 22, 2007 | 11:19 PM
shaks 442 clone's Avatar
would and front and rear sway bar from a 68 GTO fit on a 70 cutlass? the guy has front and rear the diamater is 1.5 inches not sure if thats stock or after market
but would the GTO sway bars bolt up?
Old Jul 23, 2007 | 07:45 AM
Yes they fit and yes they're aftermarket if they are 1 1/2". I think only Herb Adams sold the 1 1/2" front and back bars. You will need the larger frame brackets and isolators for the front bar and you will definitely need boxed rear arms. These will make a tremendous difference in handling. Herb Adams used to sell special threaded inserts that swaged into the frame for attaching the front bar since the stock self-tapping bolts tended to pull out with this much stiffer bar.
Old Jul 23, 2007 | 11:46 AM
so i would have to fabricate the parts to bolt it up or?
is there a place that sells the parts?
HouTXCutlass
Oct 4, 2010 11:54 AM
bgoble
Sep 21, 2010 07:56 AM
OLDSmobility
Aug 7, 2010 10:28 AM
Alocatelli
Jul 24, 2007 09:17 PM
Dutch
Nov 8, 2006 05:11 AM
