Pitman arm seal
Old Mar 16, 2008 | 02:05 PM
scrappie's Avatar
Angry Pitman arm seal
Just tried replacing the pitman arm seal on my 71 cutlass. Was not a fun job but I was able to get the rubber seal out and install a new one. The new one did not go in that easy but it did finally seat enough for the washer and snap ring to install. The problem is that is still leaking and worse than before. Any ideas on what is wrong?
Old Mar 16, 2008 | 07:06 PM
Are you talking about the seal on the output shaft of the steering box? If so, it's likely the shaft itself is scored.
Old Mar 17, 2008 | 05:15 AM
scrappie's Avatar
How does the shaft get scored?
Old Mar 17, 2008 | 07:48 AM
Removing the old seal?
Seriously, the Chassis Service Manual suggests using a piece of shim stock wrapped around the shaft to prevent damage during seal replacement. Assuming you were careful and this is not the problem, road dirt gets into the seal and acts as sandpaper on the shaft while you drive. Same problem with crankshaft snouts, which is why FelPro sells a repair sleeve for the crank. I'm unfortunately not aware of one for the steering box.
Old Mar 18, 2008 | 04:20 AM
Jim's rare 80's Avatar
Jim's rare 80
Are you 100% sure all the parts were re-installed correctly?
Just a thought.
Old Mar 21, 2008 | 04:41 AM
scrappie's Avatar
I am pretty sure, I got both seals out and replaced them. When installing I used a big socket to seat the seals. Two seals and two metal washers and then a snap ring.
Old Feb 12, 2010 | 04:47 PM
hialeah56's Avatar
1956 holiday coupe
You probably just need to remove it again inspect the shaft and if you didn't score the shaft, as stated by Joe, reinstall a new one being extra carefull. Seals get damaged real easy, make sure you use a little grease when installing and a lot of love taps not beat the crap out of it
Old Feb 13, 2010 | 07:37 AM
Good info, but you do realize we're about to celebrate this thread's second birthday...
Old Feb 13, 2010 | 04:41 PM
hialeah56's Avatar
1956 holiday coupe
wow, I saw this on the bottom of the screen and read it and didn't notice the date, the poor olds would have bled to death by now
Fun71
Apr 17, 2015 05:47 PM
KevinBN7
Oct 29, 2010 06:35 AM
jaymann
Apr 7, 2010 09:15 PM
Brodyvonsickboy
Oct 15, 2009 10:59 AM
J-(Chicago)
May 29, 2008 04:30 PM
