Mission accomplished!!!!!!
Whats up fellas
What a Good Friday its been! After six hours of work today she is finally done! Only had the drivers side CAs, spring, sway bar, and end links left. It went pretty quick next thing i knew i was lubing the joints and torquing. Havent took her for a spin yet cleaning up the garage so both cars can get in. Got one question though........how do i torque the UCA bushing nut on drivers side rear thats the last man standing?
Im already super satisfied with the new height, looks 100% better and i know i wont bottom out anymore so cant wait to turn some corners!
Thanks to all who helped me make it through this it was quite fun and frustrating but well worth it. Beers and shots all around.
Now of to the rest of the little things........see you guys around the site
Have a great weekend!!!!
Whats up fellas
Before you go ripping around the corners though, You need to get the wheel alignment done. The car looks like it's got the right stance.
Allen - Yeah the stance is great I couldn't stop looking at it from a distance. I got at least 2.5 inches on the front. To get that bolt I just went to sears and picked up a 15/16 stubby on it. Going to try to get a alignment in the morning.
Ranger - yeah I'm already putting my head in the CM for the next project lol!
Cool Leroy, you are so far ahead of me. I'm down at least for 8 weeks. Steering box and pump rebuild. Out of curiousity, what does it measure from the ground to the center of wheel well crome?
Troy i measured from ground thru center cap to chrome on wheel well and that's 26 inches. I went from being only able to put my hand in the well horizontal and still bending some. To now putting hand in vertical and touch even on tire and well chrome. Its a great stance!
Troy, can I suggest that you also look at the 70 Assembly Manual? It also has ride heights listed on page 27. http://wildaboutcarsonline.com/membe...8/70_Sec_0.pdf
Absolutely you can suggest. I joined the Wild About Cars sight (from one of your posts on another thread.) been reviewing the CSM, but haven't looked at the assembly mannual. I think everyone here is great, and it has helped me a lot. Heck, you might as well jump on my front end thread. Rob is about 42 MAW's ahead of you. Thanks.
It's like a disease I've caught, now I do the same thing to others.
When you get around to reviewing the AM, you will probably be able to relate more to the way the car goes together. It has mostly pics of OLDS design sheets showing a huge amount of intricate detail. There's an index at the front that shows where to look, and best of all, the e-file will let you zoom in to see the details up close with real clarity. You can print just the page you want, or the whole section. Front end rebuild I found was a bit intimidating AT FIRST, but then it got more comfortable.
