Installing new front upper control arm bumpers, 72 cutlass
Old Nov 27, 2015 | 04:52 PM
Oldssupreme's Avatar
Chris
Hi everyone. I think i really screwed up by forgetting to install the front upper control arm bumpers when i installed the control arms and springs. Is there anyway i can get the new ones in without recompressing the spring and removing the upper ball joint from the spindle?
Thanks for all the help you have all provided!
Chris.
Old Nov 27, 2015 | 05:07 PM
Chris.
You should be able to get then in place by jacking under the spring instead of under the frame. If that doesn't allow enough room, while the car is supported this way you can disconnect the upper ball joint and pivot the upper arm out of the way. The weight of the car keeps the spring compressed and the shock prevents the spring from coming out anyway.
Old Nov 27, 2015 | 05:24 PM
Chris
Joe, would i have to wait until i put the body back on the frame with the weight of the engine for that to work?
Thanks!
Chris.
Old Nov 27, 2015 | 06:28 PM
Octania's Avatar
Yes, probably.
However I have sucessfully managed such tasks by chaining the frame down to the legs of a cherry picker then using its boom to lift up on the lower control arm, which then allows the upper CA to be free of forces. Rather than engine/ body weight to keep the frame down, you use the crane legs. Chain securely all connections.
Old Nov 27, 2015 | 07:00 PM
Chris
Ok, thanks! Itw so frustrating to have to do all this additional work that, if i been paying better attention, would have taken me all of 2 minutes in the first place. Ah we live and learn lol. Thanks!
Chris
Old Dec 5, 2015 | 10:10 AM
Chris
Thank you all for your replies! Joe, you are thinking i can jack up under the spring, and then remove the castle nut of the ball joint? And the weight of the car would keep the arm from breaking loose and wild?
Chris
Old Dec 5, 2015 | 10:20 AM
Chris
Actually, the shock in the center of the spring prevents it from going anywhere. The weight of the car compresses the spring sufficiently that you can get the upper control arm off and on again. You do have the engine and trans in place, correct? If not, there likely won't be enough weight.
Old Dec 5, 2015 | 10:37 AM
Chris
Joe, no right now the body and engine are not installed. So what if was to jack it up under the spring like you said, and wrap a chain around the frame and the bottom of the jack to simulate the. Weight of the motor. Would that work?
Chris
Old Dec 5, 2015 | 10:58 AM
Chris
Sounds like Chris' suggestion with chaining to the engine hoist. At this point I might just resort to an internal spring compressor. What you really want is the factory style that uses a threaded rod between the upper shock mounting hole and the hole in the lower control arm.
Old Dec 5, 2015 | 12:16 PM
Chris
Joe, where can i get one of those?
Old Dec 5, 2015 | 01:37 PM
That one was home made. Description is here.
Here is another home made variation.
I got lucky and was able to score one of the Burroughs Tool Oldsmobile factory tools a few years ago. I used it when I did the front end rebuild on my wife's 1985 D88. It was so much easier to use than the aftermarket compressors.
Old Dec 5, 2015 | 01:39 PM
Chris
Thank Joe!
Chris
Old Dec 5, 2015 | 03:38 PM
I would just wait until you have most of the weight back on the vehicle. Then you can just support it on the lower control arm and worst case break the upper ball joint loose and install them. There is no harm or damage being done by waiting.
Old Dec 5, 2015 | 06:13 PM
Chris
You're right Eric. If I'm feeling cautious, ill take your advice and wait. If I'm feeling adventurous, then ill try the other methods, Thanks to all of you for your help!
Chris
DR_DAN
Mar 9, 2015 05:48 PM
bigwillystyle
Dec 21, 2009 10:05 AM
therobski
Oct 24, 2009 01:54 PM
nohn
Sep 22, 2007 11:26 AM
tiparosa
Feb 26, 2007 10:43 PM
