Hurst shifter
Hurst shifter
Ok I am looking for a shifter to fit my 70 cutlass. It currently has the turbo 350, with the center console. I am looking at getting a 4 speed trans from bowtie overdrives, bto 765r4.
But I want to have the cool hurst his/hers shifter in my olds to have the racing side, so I dont miss any gear changes!
I know hurst sells the shifter, but is it the same that came stock in the 442's and hurst olds? I would like to see it bolt in and then add the shift detent for a 4 speed. I have seen one for the hurst shifter, so I know its available. http://www.bowtieoverdrives.com/cata...php?ITEMID=429 this isnt one for the his/her shifter, but somewhere I saw one for it.
So my question is, is the shifter still available?? Or should I look for a used one?
Ok the shifter isnt available anymore from hurst. I thought you could still get it from hurst??? Must of been years ago when I last looked for it! Wow! So I have to get a used one now. Has anyone else done this swap????
You can post a parts wanted ad here for a used dual gate and watch ebay. They're still around. Then this company sells a kit with all the parts you need to convert a dual gate to a 4 speed automatic. John
http://www.shiftworks.com/cutlas.htm#7072
You would need the correct dual gate shifter to floor mounting brackets, which I believe are being reproduced. Then you would need to cut out the opening of your console to fit the larger top plate in. There are cut lines on the underside of the console that the factory used for the different applications.
Price can be all across the board. One that is complete but needs cleaned up may be $200. Then one that's been restored or is pristine may be twice that. There's a lot of different models out there, so if you want to install it in a console be sure you get the right one. Many many years ago I purchased a dual gate from a 1968 GTO and cut a huge hole in my 1971 console to make it fit. Well.... when I was young and just learning about these cars I did more than one thing that I later regretted doing
I saw on the year one site they can be had for like $680! WOW!
Im surprised the GTO shifter woudnt fit in the Olds??? So I guess the dual gate shifter that hurst sold as aftermarket would require some mods as well?
And on the cutting up the console, well at least you did it years ago right?? If you had just recently cut it up, it would of cosed more money to replace! You live and you learn
67442nut
September 16th, 2017 01:23 PM
marxjunk
June 12th, 2014 12:34 PM
