View Poll Results: What springs would you recomend?
oem replacements
66.67%
1" drop
33.33%
1" raise
0%
Voters: 3. You may not vote on this poll
front spring height
Old Mar 27, 2011 | 05:26 AM
mn olds 442's Avatar
front spring height
I am going to change the front springs in my 69 442. Does any body know what factory ride height was and how to measure this. So many different springs available.
Old Mar 27, 2011 | 07:05 AM
Bluevista's Avatar
Registered
Who are you?
It's called the carrying height and what it should be and where to measure it is in the Oldsmobile chassis service manual.
If you don't have one your next question better not be "How do I change the springs??".
Old Mar 27, 2011 | 07:30 AM
firefrost gold's Avatar
level ground, fill gas tank, empty trunk , check tire pressure, seat rearward, door closed. At about 1/2" from front of the rocker panel (not fender) 9-1/2 . In the rear about 1 inch in front of the wheel well opening 9-5/16 with a 1/2 to 1 inch tolerance 3/4 from side to side
hope this help's
Old Mar 27, 2011 | 07:31 AM
2blu442's Avatar
Yes, if your wanting to keep your ride height stock go after the stock replacement springs. I use the Chassis Service Manual like a Bible when I tinker with my cars. If you don't have one I'd strongly encourage you to pick one up. They're on ebay all the time, here's an example of one:
http://cgi.ebay.com/ebaymotors/1969-...item2ea34392ac
John
johnnyjaws
Feb 23, 2015 04:30 PM
Markbgt01
Suspension & Handling
15
Apr 28, 2014 03:45 PM
hurstman1972
May 22, 2012 07:50 PM
Longhorncutlass
Mar 2, 2009 01:53 PM
Want-A-Vert
Jan 7, 2007 05:39 AM
