Front Inner Wheel Well Repair
Old Feb 10, 2017 | 10:08 AM
RROLDSX's Avatar
I removed my drivers front fender but spun two of the clip nuts on the inside plastic fender well. This left me with two "bites" out of the fender well where the clip nuts should go. Anyone had any luck repairing them? So far I had planned to pop rivet pieces of thicker sheet metal or aluminum over them to effectively give me a new lip or edge. Any other better ideas?
Old Feb 10, 2017 | 10:49 AM
Reconstruct the missing/torn area with a plastic welder. Be sure to use anti-seize liberally when reassembling.
Old Feb 10, 2017 | 11:08 AM
jensenracing77's Avatar
X2, Plastic welders work good but you have to play with them on other stuff for a while to get the hang of using them. Watch some you tube videos also help. Just be sure you use a plastic welder and not a soldering iron. If the plastic is smoking it is to hot.
Old Feb 11, 2017 | 11:13 AM
RROLDSX's Avatar
Thanks guys, what do you use for filler plastic? Do you need a donor liner or is there something else available?
Old Feb 11, 2017 | 04:04 PM
I use plastic from a donor liner but most of the good plastic welders come with some good stuff you can use also.
Old Feb 12, 2017 | 10:12 AM
RROLDSX's Avatar
Thanks again. Looks like I'm gonna need more tools...��
Old Feb 13, 2017 | 10:35 AM
oldsguybry's Avatar
NOVICE car nut
Plastic welder is just what I need for the same problem . I'll have to do a search on how much they cost .
Old Feb 13, 2017 | 12:04 PM
RROLDSX's Avatar
Bought a plastic welder today at HF and some ABS plastic. I will update this post on my progress but it will be awhile.
Old Mar 6, 2017 | 01:08 PM
RROLDSX's Avatar
My plastic welding sucks so I didn't take pictures. I did manage to establish enough of a plastic filler piece to fill in the bite areas using the welder. It takes practise, I'm not sorry I bought the welder as it will come in handy in the future. I ended up covering my plastic debauchery with the epoxy putty HF sells. You knead it to activate before you apply it. It ends up with the texture of plasticine until it sets hard. Here is a picture of the finished product. Luckily it won't be visible behind the fender lip.
Old Mar 6, 2017 | 01:50 PM
Don't look bad and installed nobody will know. I just got a new welder myself but have not tried it out yet. Here is a hole that I fixed a while back. I could clean it up more and make it prettier but it would take several more hours, with nobody able to see it when installed so it is not worth doing more to it.
Old Mar 6, 2017 | 01:55 PM
RROLDSX's Avatar
Yours look better than mine but then again yours are more valuable as well. Nice job and thanks for the advice.
Randy
halfmoontrail
Aug 19, 2013 08:47 PM
RandyS
May 5, 2013 04:23 PM
1k442
Sep 8, 2010 07:16 AM
rock350it
Apr 11, 2010 03:37 PM
Nilsson
Apr 13, 2009 08:54 AM
