Front fender to frame mount question
Old Sep 22, 2007 | 10:42 PM
72rocket's Avatar
Question Front fender to frame mount question
I just pulled the support beam that goes from the front fender (by the side marker) to the frame and drilled out the rivets holding this rubber/fabric material to the beam so I can strip/paint the beam. The rubber/fabric stuff is trashed and I'm wondering if anyone has had experience getting this new material or maybe an idea on a thick rubber sheet I can cut to size to replace it. I'm just going to use a nut, bolt, and washers instead of the rivet to reattach it so that's easy.
Any help would be great.
Old Sep 23, 2007 | 03:34 AM
Bluevista's Avatar
Registered
One of the rubber pieces on mine (all original) has part of a whitewall on it. I think they may have used some sort of old tire pieces? There is also a pattern on the backside like the inside of a tire.
Allan
Old Sep 23, 2007 | 10:39 AM
72rocket's Avatar
You know, that makes sense now that you mention it. I can see what looks like cords in the material, but no whitewall to tip me off. It's just shredding apart. Mines all original also. I think I'll just go down to a tire store and grab an old used tire and cut out the pieces I need since I saved the old piece to use so I could cut the right size. Thanks for the quick assistance Allan!
Old Sep 24, 2007 | 07:14 AM
Oldsguy's Avatar
Past Administrator
Hacksaw works well and less effort than a knife, unless you happen to be Samauri Sam or something..
dfire25
Feb 24, 2014 06:43 PM
matviar
Oct 9, 2013 05:59 PM
Shradezz70S
Jun 1, 2013 05:23 AM
67 black goat
Apr 21, 2013 06:56 PM
Al Graaf
Mar 26, 2012 09:36 PM
