Frame rust repair by steering box
Old Aug 31, 2013 | 12:48 PM
seanm12's Avatar
Car is a 67 Cutlass Supreme convertible. I was working on the engine compartment, stripping down the frame and painting it. I saw what looked like a couple small rust spots where the steering box is bolted to the frame. I took the steering box off, drilled out that spot and tried to fix it with my TIG welder. It bubbled and had some porosity. I drilled out that stuff and welded that spot, and when that other area got hot I got more porosity, and after repeating things a few more times I figured out I'm pulling in rust and oil from the inside and needed to dig deeper. I found some extra holes on the bottom where the sway bar bolts in and cut a hole to see what was really inside. What I thought was 2 small spots was the tip of the iceberg. I think I have cut out enough to be down to good metal close enough to the original 1/8" thickness. Later I'll be tweaking angle iron to match the way this part of the frame was pressed when it was made.
Old Aug 31, 2013 | 12:53 PM
seanm12's Avatar
Pics 1
seanm12's Avatar
Pics 2
Old Aug 31, 2013 | 12:54 PM
seanm12's Avatar
Pics 3
Old Aug 31, 2013 | 12:58 PM
svnt442's Avatar
Ya got some fuzz growing from somewhere there....
LOL!
But seriously though...nice work. It's amazing how rust can hide on ya.
Old Aug 31, 2013 | 01:51 PM
Wow. That ain't too pretty at all.
Should be fine after welding up with good metal, though.
Old Sep 1, 2013 | 06:37 AM
Run to Rund's Avatar
Check elsewhere on the frame for rust!
Old Sep 1, 2013 | 03:25 PM
seanm12's Avatar
svnt442 (Randy) - Thanks for the funny response! I got a good chuckle.
Run to Rund - Yep, will check for more frame rust, starting with the other side where the sway bar bolts to the frame. Fabricating the pieces to replace what I've cut out will take a lot of time as most of what I cut out was pressed with a lot of bends. I'll post more pics as I move along with that fabricating.
Old Oct 6, 2013 | 04:59 PM
seanm12's Avatar
Frame repair part 2
OK, got most of the repair done, and time to post some pictures. I took a lot and will post them 5 at a time. I wanted to share what I figured out as I went through this repair since I get plenty of info from other folk's posts. Here's some comments for all of the pictures:
1. I started by cutting out 1 part, then another, then another. That's the old rusty parts tack welded back together to show what I needed to replace.
2. After a bunch of cardboard templates that's what I created from 1.5" x 2" angle iron after a bunch of cutting and bending. The bottom of the frame is about 3" wide so 2 2" wide angle iron gave me a good starting point to lap weld instead of butt weld.
3. Sorry the tack weld pictures are fuzzy. I was pretty tired then.
4. The picture with 3 parts if from making one twice. The 1st one (middle) ended up being too small. A whole bunch of crazy bends!
5. How I figured out where to drill the hole for the 3rd bolt. I used washers to space the particleboard over the round steering box.
6. I got a piece of gas pipe from the hardware store for the tube that goes between the bolt holes.
Old Oct 6, 2013 | 05:00 PM
seanm12's Avatar
Frame repair part 3
Pics part 3
Old Oct 6, 2013 | 05:02 PM
seanm12's Avatar
Frame repair part 4
Pics part 4
Old Oct 6, 2013 | 05:03 PM
seanm12's Avatar
Frame repair part 5
Pics part 5
Old Oct 6, 2013 | 05:05 PM
seanm12's Avatar
Frame repair part 6
Pics part 6
Old Oct 6, 2013 | 05:06 PM
seanm12's Avatar
Frame repair part 7
Pics part 7
Old Oct 6, 2013 | 05:08 PM
seanm12's Avatar
Frame repair part 8
Pics part 8. The end!
The welds were done by TIG. That's the 1 welding machine I have.
Next to drill and tap holes for the stabilizer bar!
Then may get back to painting this dagom frame!
Old Oct 6, 2013 | 06:11 PM
Nice work! I'm impressed.
You may want to weld in nuts for the sway bar bushings, as the original threaded holes occasionally strip out.
easytobedead
Paint
Apr 10, 2009 06:16 PM
lshlsh2
Body work
Mar 4, 2009 03:27 PM
Frankenpez
Feb 2, 2009 07:03 PM
scott_442
Dec 12, 2008 07:57 PM
nosrevle
Mar 18, 2006 01:24 PM
