Frame exchange ? 1965
Old Jul 29, 2007 | 04:03 PM
JAL55's Avatar
I want to know if I can swap the frames on my 1965 98 luxury sedan( this is the cherry frame) with my 1965 98 convertible ( this frame is rotton with rust)? All that I have measured seems Identical, and I'm not far from taking the tub off the convert. but does anyone know if it will work?
Old Jul 29, 2007 | 04:20 PM
Unless your sedan came with the optional heavy duty frame (which was simply the convertible frame under a sedan or hardtop), the fundamental problem is that the convertible frames were fully boxed to make up for the loss of rigidity when the roof was removed. Sedans without the HD frame option got an open section frame.
And since the question always comes up, boxing the sedan frames on a 60s car like this IS NOT the same as boxing a simple street rod frame. The factory used complex C-shaped stampings that were tailored to fit the floorpan. The trans crossmember mounting is different, as is the crossmember.
It is possible to cut the welds and remove the boxing sections from the covert frame and weld them into the good sedan frame. The outer sections of the frame rails were the same, it's this additional inner section that's different on the convertibles.
Now, if your sedan already has a fully boxed frame (in other words, it was ordered with the HD frame option), then this is a bolt-in swap.
Old Jul 30, 2007 | 10:15 AM
Originally Posted by Oldsfan
Joe, I've read your post 3 times now, and I'm still confused. Why isn't this a bolt-in swap unless the car was originally equipped with a H/D frame? Mounting positions should be the same, wheelbase should be the same. Only differences are the boxed sections and cross member as you mention, but these should be compatible with a 98, whether it's a convertible or not, no? Am I over-simplifying?
Paul
OK, the sedan frame WILL bolt up to a convertible body, but it WILL NOT be structurally adequate. That's why you need to weld in the reinforcements. I call that a little more work than "bolt-in". The HD frame option IS a convertible frame.
Old Aug 4, 2007 | 06:21 AM
JAL55's Avatar
Joe, thank you for the information, I feel alot better now for buying the sedan. I'll let you guys now how I make out. I'm sure I'll be posting plenty more questions during this project.
Jacoz70442
Jun 26, 2018 06:52 AM
jchavis44
May 9, 2012 09:13 AM
ctrain22
Dec 15, 2009 09:36 PM
toymaker199
Jul 15, 2009 09:43 AM
