Fact or Fiction
If you do a google search under "repair dent with dry ice", enough sites pop up saying you can that it seems worth the try, particularly since dry ice is not expensive. What have you got to lose? It does make sense from a physics point of view because the dry ice, being so cold, causes the metal to contract.
But, as noted, be careful. Wear well-insulated gloves as holding dry ice in your hand can cause frostbite in no time. The temperature of dry ice is -109 degrees F. Also, make sure you're in a well-ventilated area as it's pure carbon dioxide and can decrease the percentage of oxygen in a small space as it evaporates (sublimate is the actual term).
Let us know if it works as I have a few small dents like that in the hood of my truck.
