cutlass trunk rods are broken
Old Sep 28, 2010 | 09:36 AM
veltboy618's Avatar
I bought a cutlass thats in better condition as far as the body & frame (kind of butchered on the inside) than the one I'm currently driving so i'm going to switch everything over to that one but the rods that help lift the trunk are broken on the passenger side. is there any way to fix these?
Broken side
Old Sep 28, 2010 | 09:53 AM
Run to Rund's Avatar
They are spring steel (torsion bars) so can't be fixed. You can remove them with a home made tool. Get a piece of 1" pipe or similar tubing about 1.3-1.5" OD, and notch the end to fit onto the long area of the rod. Drill a 3/8" hole crosswise a couple inches down from the notch (see what is right for your year car) and install a carriage bolt and nut. The bent part of the rod goes under the carriage bolt head and you now have a lever to put more tension on the rod and get it out.
Old Sep 28, 2010 | 10:02 AM
veltboy618's Avatar
Thanks again buddy! I post on a couple different sites because you will get a quicker response on some sites
truchagrande
Aug 15, 2012 07:25 AM
724drcutlass
Feb 25, 2012 05:13 AM
K_Dubb
Oct 7, 2010 07:37 AM
cfair
Jul 22, 2009 12:10 AM
Flye
Apr 7, 2009 01:17 PM
