Check list for body separation from frame
I have the front portion of the body ready to remove from the frame on my '68 Cutlass (I have jacked it up to check). I am now getting ready to lift the rear part of the body. Can someone please provide a checklist of things that need to be removed at the back so I don't mess anything up (ie bumper, lines, etc.)?
Dave
Dave
This is not that hard but really need to know what you did so far. If the front clip is off with all associated wiring then you must still disconnect all engine/tranny wiring. disconnect the steering column at the rag joint, brake lines at the distrobution block, ground wires to the firewall behind the passenger cyl head, backdrive linkage from column to tranny, rear light wiring and fuel sender wiring (all in the same area) and the rubber hoses from the tank to the frame mounted lines. Oh! and the body to frame bolts. lift slowly to make sure you havent missed anything. If the clip is not off you must disconnect radiator hoses and tranny lines, forward light harness, fender to frame braces, support mounts, and wheelhouse to frame bolts.
67delmont330
July 31st, 2012 06:13 PM
sixty9olds
June 14th, 2011 06:43 PM
1969goatman
August 30th, 2010 07:44 PM
