Change frame on a cutlass -68 cab?
Hi
First post in this forum, but I have a question.
Bought a "new" car, a cutlass cab -68. The frame was bad (rusted) but the owner had a used frame from a 442 cutlass cab -69.
But to the problem, I found a vin number on the new 442 frame behind the left rear tire, but om my old I can't find any vin number on the same spot? And the old frame is so rusted so then I need to grind the hole frame trying to find it.
Is there a vin number on the -68 frame but on a diffrent location?
BTW the "VIN" number behind the left rear tire isn't the VIN, it's the frame number. The VIN number is on top of the frame just behind the door. You can't see it without a mirror and even then probably not. My frame wasn't that rusty and I couldn't even find it
Look at this thread:
https://classicoldsmobile.com/forums...ive-frame.html
and I was wrong about just behind the door. It's on top of the frame just aft of the front body mount and just aft of the rear wheelhouse in 68
Just to clarify, the number stamped on the frame (and the block and transmission case) is not a 13-character VIN, it is a nine-character VIN derivative. The first character of the VIN derivative matches the first character of the VIN, and the last eight characters of the VIN derivative match the last eight of the VIN. What the VIN derivative does not have are the second through fifth characters of the VIN that tell you model line and body style.
I supposed, if it makes you happy, go ahead and add it.
As far as where on the frame, have you read the thread I posted above?
If not, here's an excerpt posted by an Engineer that worked at Oldsmobile in 1968:
Requirements were to have at least one fully legible VIN on the frame rails. We hit it twice with a huge machine that rolled the numbers into there. Even at that, sometimes the repairman had to manually stamp one or more of the numbers that didn't come through.
Frames were upside down, hanging from an overhead monorail conveyor the first half of the chassis line and VIN stamp was one of the first operations. It is on the drivers' side top surface between the body and frame and almost impossible to read with the body on. The front one is between the torque box (cowl area) and the trans crossmember. The rear one is behind the rear wheel kickup. PLacement varies a coupla inches fore and aft.
Jimmi V.
Cars Wanted
Mar 2, 2013 04:22 PM
