Can't get any grease through a fitting.
Old Apr 5, 2010 | 11:38 AM
henryk8398's Avatar
Hangin' out...
Cool Can't get any grease through a fitting.
So I'm greasing the zerk fittings on the 98, when I realize I can't get anything through one of the fittings. Specifically, the pitman arm to centerlink. All the grease seems to be leaking out of the fitting. I thought maybe I had a clogged fitting, so I replaced that, too. No dice. Time for a new centerlink or is there something else I can do? Solvent? Torch? Any ideas? Thanks!
Old Apr 5, 2010 | 01:48 PM
If you've replaced the zerk fitting and you know your grease gun end tip is in good shape, then you need to soften the grease in the pitman arm. Heat is probably your best bet, but be careful not to melt the rubber bushing or catch the grease on fire. A heat gun might be better than a torch, albeit a lot slower.
Tedd Thompson
May 20, 2015 07:21 AM
mmurphy77
Site Help
Sep 12, 2011 10:32 AM
Flye
Aug 24, 2009 05:46 AM
aholiday
Jul 24, 2009 05:18 PM
cfair
Jul 16, 2009 11:00 AM
