Boxed Rear Control Arms
Old July 25th, 2008, 08:16 PM
Senior Moment Member
z11375ss's Avatar
On my W31 clone car the lower control arms have been boxed with what looks like 3 inch square plates welded to them. They kind of overlap each other and span the lenght of the arm. Does anyone know if this is the way the factory did it? Did the factory do it at all?
z11375ss is offline
Old July 26th, 2008, 03:22 AM
The factory used a plate fabricated from a single strip of sheet metal that had two "U" shaped bends in it, one at each of the sway bar bolt holes. These act as spacers to prevent the arm from being crushed by the bolts. The plates were welded to the control arms with a series of welds each about 1" long.
joe_padavano is offline
Old July 26th, 2008, 06:02 AM
z11375ss's Avatar
Thanks Joe, they look the same as mine so I know now they aren't fake. Like the rest of the car.
z11375ss is offline
Old July 26th, 2008, 06:03 AM
Wireman134's Avatar
You can find the the factory type insert at OPG they just weld in...
http://www.opgi.com/product.asp?topc...195&yearrange=
Wireman134 is offline
Old July 26th, 2008, 06:04 AM
z11375ss's Avatar
Of course OPG has no pic. Sheesh. Man we're all up early. What the hay.
z11375ss is offline
cut123
March 28th, 2013 08:54 AM
66-3X2 442
October 4th, 2011 09:13 AM
JSGD1966
October 5th, 2010 08:26 PM
Olds luvr
January 19th, 2009 06:35 AM
Quick Reply: Boxed Rear Control Arms
