A-body upper ball joint question
Old Nov 28, 2009 | 12:39 PM
f85mark's Avatar
Could anyone give me some advice regarding the removal of the upper ball joint from the steering knuckle? I tried using a pickling fork, but it doesn't seem to work. Thanks.
Old Nov 28, 2009 | 01:24 PM
gearheads78's Avatar
car guy
Get a bigger hammer. The pickle fork will work. If you want to cheat get a fork that goes into an air chisle.
Old Nov 28, 2009 | 01:45 PM
2blu442's Avatar
Make sure you have the right sized pickle fork, years ago I got one that was too wide or too narrow and it wouldn't fit. Also make sure your going perpendictular to the drum/disc so your not bottoming out the fork tooth on something. I agree with Richard, sometimes they're really subborn and need some serious wacking!
Old Nov 28, 2009 | 02:50 PM
OLDSRALLYE350's Avatar
Place a bar 4 foot or longer under the control arm so that upward pressure can be applied, leave the ball join nut on a couple of turns so when it comes loose it does not fly upward, strike the steering knuckle with a big hammer on the side next to the ball joint shaft where it goes thru the knuckle, should come loose after several strikes, this way will not damage the rubber boot on the ball joint.
Old Nov 28, 2009 | 03:37 PM
jensenracing77's Avatar
I'm sure that you have it under control but you do have the spring tension off , right? don't want anyone to get hurt. i use the fork in the air hammer. and also sometime use a pry bar with the air hammer.
Old Nov 28, 2009 | 04:03 PM
Run to Rund's Avatar
I don't like pickle forks because of the possibility of damage; probable damage to the rubber boot. Remove the cotter pin, back off the nut 1 turn, jack under frame with spring tension on the joint. Hit the side of the knuckle on the boss forged into it, using a short handled 3 pound hammer.
Old Nov 29, 2009 | 04:10 PM
f85mark's Avatar
Success! Thanks for the advice everyone. I just wasn't applying eneough force. The bigger hammer made the difference.
Old Nov 29, 2009 | 06:18 PM
Lady72nRob71's Avatar
Pickle fork thingie BAD! Hammer GOOD!!
Old Nov 30, 2009 | 09:53 AM
Originally Posted by f85mark
...The bigger hammer made the difference.
Every toolbox needs a BFH...
Old Nov 30, 2009 | 12:13 PM
Bluevista's Avatar
Registered
If you can't do it with a BFH get a BiggerFH.
I have a BFH, I call it Mjolnir and Odin gave it the power to smite all ball joints and evil.
Call me Thorvista.
willypsilon
Suspension & Handling
24
Sep 23, 2014 10:26 AM
arcee1951
Mar 15, 2014 11:03 AM
shovel55
Mar 3, 2013 12:57 AM
Ranzan
Sep 7, 2010 09:17 PM
defiant1
Apr 13, 2010 09:32 AM
