Body lean after new shocks and springs
Old Jun 27, 2020 | 11:49 AM
HarrySlother's Avatar
I just put 2 inch lowering springs in the front of my 72 Cutlass and now it's leaning to the passenger side. I can fit about three fingers in-between the fender and tire on the driver's side and almost one on the passengers side. im not even sure if the driver's side lowered at all. There was no lean before.
Old Jun 27, 2020 | 12:18 PM
Wow, the car must have been really high to begin with. I have Moog 5536 springs on front of mine and it sits at the correct ride height per the CSM specs. You can see the fender to tire gap in this pic.
As for the lean, did you tighten the suspension bolts with the weight of the vehicle on the suspension?
And are you certain the springs are correctly aligned in the lower control arms? The bottom coil of the spring should be in the slot and the end of the spring should be just short of the hole at the end of the slot.
Old Jun 27, 2020 | 12:20 PM
Orlando 1's Avatar
O'smobile
Assuming you confirmed all part numbers are correct, make sure the spring is in the right rotation. The coil end should be right up against, but not covering, the little drain hole in the cup of the bottom a-arm. Also, there are guides to position the top of the spring. If you are on one of those and not seated fully that would increase height.
Old Jun 27, 2020 | 04:04 PM
Thanks for the advice guys. I ended up taking the driver side apart and the spring was not seated correctly. What was throwing me off also is my sway bar was bent so I wasent sure if it was something more. It's all good now and sitting correctly.
Old Jun 27, 2020 | 06:54 PM
vCode442's Avatar
Vincit qui se vincit
And that’s why Classic Oldsmobile is such a freaking amazing place. Two excellent replies with one hour of the initial question. Wouldn’t it be nice if everything in this world functioned as well👏
plee3 64Olds
Suspension & Handling
May 8, 2013 06:28 PM
J-(Chicago)
Nov 7, 2011 08:19 AM
pcard
May 14, 2011 02:54 PM
Olds Dad
Jan 26, 2011 12:50 PM
Eddie Hansen
Mar 30, 2010 07:36 PM
