Adjusting Convertible Roof
Old Sep 3, 2020 | 11:44 AM
sjay1989's Avatar
All,
When I latch the roof on my 69 Cutlass, the gap on the drivers side between the roof and the header panel on the car is quite a bit vs. the passenger side. The passenger side seals much closer/tighter. The driver side latch also doesnt seem to pull the roof down as much as the passenger side. I havent been able to find any ways to adjust the latch or roof in any way to make sure the roof seals completely to the car. Would appreciate a link to a post I may have missed.
Old Sep 3, 2020 | 12:26 PM
The hooks on the latches are adjustable - they are threaded and can be shortened or lengthened, but that may not be your issue.
When the top is put up fully, and before the latches are connected, is the front bow parallel to the top of the windshield? If not, one of the pistons may not be fully extending, the top frame mechanism may need to be adjusted, etc.
On my car, when the top is raised the front bow will make contact the windshield across the full length, and the latches just snug it down.
Old Sep 4, 2020 | 09:45 AM
acavagnaro's Avatar
X2 on that. When you put the top up and release the switch, the top should be resting on the windshield header. The knuckles on the latches are adjustable but the latches shouldn't be pulling the header down, they should just be latching the top firmly in place.
1971 cutlasssupreme
Jun 19, 2018 07:46 PM
72Cutlass_442
Body work
May 17, 2018 08:08 PM
dc2x4drvr
Mar 23, 2014 03:56 PM
lumbertm
Body work
18
Sep 29, 2012 01:34 AM
rennoc442
Oct 28, 2010 02:32 PM
