80-85 A-Arm cross shafts
Old Jun 18, 2008 | 10:24 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Question 80-85 A-Arm cross shafts
Here's one for the books...
On both of my 85 delta 88s there are flat shafts on the driver's side
the passenger ones are round like the g body cutlass ones.
Were they just running out of parts in 85? or is there a reason for the rounded one? I mean if it's flat or rounded no big deal I guess as long as the shimming is correct.
I sold my 80 delta in January and cannot check it to see if it is the same as the 85's
Anyone?
Also.... how do I determine the new amount of shims needed If I use 2 offset(flat) crossshafts?
Old Jun 19, 2008 | 07:50 AM
Anyone?
Well, I've seen both flat and round from the factory. There are lots of cases where the factory used multiple suppliers and the parts may have looked different but functioned the same. In all cases, however, the factory installed shafts were not offset. The one you've shown in your photo is an aftermarket offset shaft that is designed to correct cases where the frame has sagged or for whatever reason there isn't enough shimming to properly align the front end. As for how many shims you need - well, that's up to the alignment machine.
cutlasssupreme71
Drivetrain/Differentials
Feb 22, 2011 11:40 AM
my72vert
Jan 1, 2011 07:36 PM
geckonz08
Mar 17, 2010 04:50 PM
ragtop442
Dec 31, 2009 05:45 AM
monzaz
Jul 6, 2009 07:51 PM
