'69 Cutlass lower fender to cowl bolt removal
Old May 28, 2017 | 01:31 PM
bardcutlass's Avatar
I am trying to remove the front clip on my '69 Cutlass wagon, the lower fender to cowl bolts are spinning freely, it seems the sheet metal "nut" has broken loose, what is the best way to remove them?
Old May 28, 2017 | 04:09 PM
The ONLY way to remove them is to cut the heads off, unfortunately. This is a common problem. I use a cutoff wheel in my 4 1/2" Dewalt grinder. Use LOTS of anti-seize when you reassemble with new J-nuts.
Old May 29, 2017 | 09:23 AM
I suspected as much, thanks for verifying it!
Old Jun 18, 2017 | 03:04 PM
Got those off, now trying to remove the front clip and having an issue. I found these instructions:
disconnect wiring. I do it at the fuse block junction.
disconnect radiator
If you have a/c there is a couple hoses to condenser, also hose to compressor is clamped on passenger fender.
disconnect windshield washer hoses
remove battery and disconnect ground strap from passenger fender.
2 bolts holding fender to door jamb
4 bolts fender to cowl
4 bottom fender to cowl bolts
4 wheel well to cowl bolts
2 core support bolts
I have found and disconnected all bolts except the 4 wheel well to cowl bolts, where are they?
Old Jun 25, 2017 | 09:12 AM
Finally got the from clip off!
Old Jun 25, 2017 | 10:01 AM
Gary M's Avatar
What are your plans for it?
makin good progress.
prohandze
Jan 30, 2017 08:08 AM
dallasite21
Feb 24, 2012 01:34 PM
Alex72cutty
Feb 7, 2012 07:32 PM
frasco
Sep 15, 2011 05:56 AM
frasco
Body work
Sep 14, 2011 10:25 AM
