‘68 442 Fuel Tank
Old Mar 19, 2019 | 03:26 PM
teamwieland's Avatar
‘68 442 Fuel Tank
Upgrading to run E85 with a frame mount electric pump. As such need to weld a sump kit which will require cleaning stock tank or buying a new tank. I realize the stock tank is 17 gallons but several are advertised as 20 gallon tanks. Sure would be nice to have the extra 3 gallons considering I’ll be using gas at a much faster rate. The first one from tanks Inc. is advertised as 20 gallons but I just called and they said it is identical to the stock tank so must be 17 gallons. Second one I found on eBay the same story. Are there any tanks that have larger capacity or is it safe to say all tanks will be 17 gallons?
Old Mar 19, 2019 | 04:52 PM
I'm not sure where you get 17 gallons. Per the capacities chart in the CSM, the tank is 20 gal US, which is 16.75 gal Imperial. I personally have squeezed just over 20 gal into one of these tanks (and the car had not quite run out of gas...).
Old Mar 19, 2019 | 05:20 PM
Thanks Joe. You maybe have answered my question inadvertently. Perhaps some show imperial and some show U.S. although I don’t know why imperial would be used on an American car. One of the ‘oem’ tanks I saw said 64 Litres, which converts to 17 U.S. gallons.
Old Mar 19, 2019 | 07:31 PM
Yellowstatue's Avatar
The people in the frozen North used to use Imperial measure. Nowadays mostly metric!
Old Mar 19, 2019 | 07:54 PM
BackInTheGame's Avatar
In case you decide to go new on the tank, RA has two models for pretty cheap, plus one that is more than twice the cost. I paid ~$125 for mine two years ago..
jensenracing77
Aug 28, 2017 04:47 AM
matchek
Apr 1, 2015 06:37 AM
lass4ken
Dec 21, 2012 03:16 PM
68vaolds
Jan 4, 2011 07:18 AM
cegulley
Oct 1, 2010 03:37 PM
