455 Frame Mount Location
Old Aug 25, 2013 | 07:58 PM
dfire25's Avatar
"Trying to fix her right"
Hi everyone,
I'm in the process of replacing the 350 (the engine that came with my car) in my 1971 442 with a 455 (the engine that should be in the car) and this is what I have to deal with (see pics). Yes they are welded on and up side down! I was able to remove them with a screw drive, my bare hands, and VERY little effort. Nice right? Its a good thing I'm replacing the engine, otherwise the next time I jumped on it I may have needed a new hood.
Anyway, where is the CORRECT location for mounting the frame mounts? There are a bunch of holes in the cross member, but I don't know the correct ones to use with a 455. If anyone has a diagram or pictures that would be a huge help. I plan on welding the other hole so the cross member isn't like Swiss cheese as well. Any help would be much appreciated.
Thanks,
Dave
Old Aug 25, 2013 | 08:15 PM
svnt442's Avatar
SBO and BBO mounts use the same mounting locations. they are just shaped differently from each other.
Here is where the mounts should go, on the drivers side at least, but I think that they will only bolt up properly in one spot on the frame.
Old Aug 25, 2013 | 08:21 PM
dfire25's Avatar
Perfect svnt442 thank you! Anyone have a pic of the passenger side?
Old Aug 25, 2013 | 08:22 PM
svnt442's Avatar
Passenger side:
Old Aug 25, 2013 | 08:25 PM
svnt442's Avatar
Not sure if my grungy frame will help...but....
Old Aug 25, 2013 | 08:30 PM
dfire25's Avatar
Tremendously!!!
How about that for a fast response guys, with pics too.
Thanks this REALLY helps.
Do you like the weld job the previous owner did?
Old Aug 25, 2013 | 08:36 PM
svnt442's Avatar
Yeeaah.....suuuure. Looks up to snuff to me.
Old Feb 23, 2014 | 06:08 PM
joades's Avatar
ZATBAD 72
I pulled my 350 today ago install a 455. I put on the 455 frame mounts, but I am curious why the passenger side is slotted (frame mounting holes) like the photo above while the drivers side is not. I bolted my new mount on the passenger side in the exact same spot and tightened it.....not sure I'll be having a problem later with it tightened it just sure looks like it will be hard to tighten later.
Old Feb 23, 2014 | 06:14 PM
svnt442's Avatar
Not sure why you swapped the frame mounts as it was not necessary.
Old Feb 23, 2014 | 06:16 PM
svnt442's Avatar
And so long as the new mounts are in the same spot as the old ones you should be fine.
Old Feb 24, 2014 | 07:37 AM
Go back and read his original post. The previous mounts were poorly welded to the crossmember, and upside down!
Old Feb 24, 2014 | 07:40 AM
svnt442's Avatar
Well duh.......I'm stoooopid. I kinda knew that. I even replied the pictures for him.
SMH.
Old Feb 24, 2014 | 07:51 AM
dfire's mounts were welded, but joades came in later with the statement that he swapped the mounts, and asked about the slotted holes on the passenger side. I don't know why there are slotted as the lower mounting is fixed.
Old Feb 24, 2014 | 05:49 PM
joades's Avatar
ZATBAD 72
Yes - I came in late on this. I did swap my 350 mounts out and followed the part number advice from Joe. I want the 455 to be in the right spot plus my 350 motor mounts were shot anyway. I found the 455 frame mounts on Ebay at a pretty good price. I put the passenger side on in the same spot as the old one and cranked it down. I guess worst case I'll have to loosen them a touch and tweak it.
Old Feb 24, 2014 | 06:43 PM
dfire25's Avatar
I mounted the frame pads roughly in the spot where they should be, but I still had to loosen them up to get the motor mounts to line up with them. My recommendation is to leave them loose till you get them lined up and have the bolt through the mounts and pads.
The frame pads that where on the car where different from the 455 pads I purchased. The 455's looked more reinforced. Keep in mind though that the 350 mounts where upside down and welded to the frame
Mike H.
Jun 16, 2013 07:10 PM
67 black goat
Apr 21, 2013 06:56 PM
Indy_68_S
Aug 24, 2012 10:10 AM
Al Graaf
Mar 26, 2012 09:36 PM
72rocket
Sep 24, 2007 07:14 AM
