2 1/2 engine pipe clearance
Old May 30, 2012 | 04:37 AM
2oldsguy's Avatar
I just purchased a 2 1/2 exhaust system to be used on my 70 442 455 with W & Z manifolds. On the left side I am having a clearance issue.
The original pipe was dented at the chassis side.
Should I have to dimple the new pipe or cut off part of the bracket?
Anyone else have this problem and how did you solve it.
Thanks,
Joe
Old May 30, 2012 | 05:35 AM
Rickman48's Avatar
I'd be checking the motor mounts, as when they become oil soaked, they turn to mush and collapse!
Polyurethane mounts should move it a little.
If you really want to get some room - loosen the frame mounts and jack the motor over as far as you can go, although not an easy feat with the motor in the car!
Old May 30, 2012 | 05:42 AM
dc2x4drvr's Avatar
Rickman might be on to something...I had a little clearance when I was running TT 2 1/2" headpipes with WZ's.
Old May 30, 2012 | 08:01 AM
Rickman48's Avatar
Or, pull the pipe back out, get that corner of the lower control arm bracket red hot, and adjust with a BFH!
Cool-off quickly or melt the bushing!
Old May 30, 2012 | 05:06 PM
2oldsguy's Avatar
Thanks for the replies.
If I raise the engine it will just make maters worse. If you look at the third picture raising the engine will make the pipe hit more.
Any body have a picture of their setup?
Joe
Old May 30, 2012 | 07:11 PM
Rickman48's Avatar
Yeah, but if the other side is collapsed, it'd twist the motor the right way!
Old May 30, 2012 | 07:17 PM
Rickman48's Avatar
I've seen shims to help solve problems such as this.
Old Jun 7, 2012 | 05:42 AM
2oldsguy's Avatar
Last weekend I jacked the engine up and lossened each chassis mount and was able to move them forward about 3/8". Then I installed new mounts pushing the engine as forward as possible.
This gave me more clearance.
Then I rounded off the 'A' frame bracket without removing a lot of material.
It gave me plenty of clearance. I will be installing the rest of the system this coming weekend.
I will keep you posted as to how it sounds and fits.
Joe
Before:
After
rmoths
Jul 9, 2014 03:26 PM
Macadoo
Jun 23, 2014 11:08 AM
805cut
Jun 8, 2012 03:15 PM
Devon76
Apr 15, 2007 06:45 PM
<bbyers>
May 28, 2004 09:54 AM
