1970 front upper section removal ?
Old June 5th, 2011, 11:50 PM
Aceshigh's Avatar
Looking to rip out my front upper section directly under the radiator cover for SB and PC.
(Sandblasting and Powdercoating.)
It looks like this just comes out with 3 bolts holding it to each fender,
and 3 bolts holding the hood latch in place, however, it's not coming out.
Does this ENTIRE front end clip behind the headlights going fender to fender UNDER
this have to come out in one piece ?? Anyone know where I can get a body diagram
that shows how this gets put together/disassembled ?? Thanks.
Aceshigh is offline
Old June 6th, 2011, 05:34 AM
507OLDS's Avatar
That's all welded together,as part of the core support.The radiator top plate unbolts,and the front grille support unbolts,but the rest is all welded together.To remove the whole core support,you need to unbolt it from the fenders and from the frame.
507OLDS is offline
Old June 6th, 2011, 05:47 AM
oldspackrat's Avatar
Yeah,
What Brian says, you have to remove the whole thing. Battery tray, front of the inner fenders, front lower fender braces, all front light & horn wiring, fan shroud, front of fender eyebrows, radiator, etc....
oldspackrat is offline
Old June 6th, 2011, 09:39 PM
Aceshigh's Avatar
Ahh ......oh well. Looks like I have more work to do then.
Thanks guys.
Maybe my new fender wells will go in ALOT easier this way.
Because I had one hell of a time getting the pass side out.
Aceshigh is offline
Old June 7th, 2011, 06:35 AM
Uh, "SB and PC"?????
joe_padavano is offline
Old June 7th, 2011, 06:40 AM
No it's not a parts car!!
Schne442's Avatar
I think he means sandblast and powdercoat
Gary
Schne442 is offline
Old June 7th, 2011, 01:48 PM
Aceshigh's Avatar
Gary
Yep!!!
Damn Joe, I finally found something you DIDN'T KNOW!!!!
BTW I fixed the 1st post for others who don't too.
Aceshigh is offline
Old June 7th, 2011, 02:13 PM
Had me baffled, too, but I thought I was just dumb .
MDchanic is offline
my72vert
December 9th, 2022 05:36 AM
DR_DAN
March 9th, 2015 05:48 PM
Johnd
August 28th, 2014 04:22 PM
warrior71
November 2nd, 2013 07:17 AM
Alex72cutty
February 7th, 2012 07:32 PM
Quick Reply: 1970 front upper section removal ?
